Go to Post Remember those two words people. Gracious Professionalism. - Elgin Clock [more]
Unread 10-02-2008, 20:01
legotech25's Avatar
legotech25 legotech25 is offline
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
legotech25 will become famous soon enoughlegotech25 will become famous soon enough
Send a message via AIM to legotech25 Send a message via Yahoo to legotech25
off board compressor
Hi.
We're using an off board compressor, and we noticed that the inspection checklist said that we needed to mount the 125psi regulator on our robot. We intended on limiting the entire system to 60psi, including the storage tanks and everything else. Can we use 1 regulator set at 60psi, or do we need to mount the 125psi regulator directly behind our first regulator?
Thanks for your help!!! ^_^
Team Captain - More Robotics 1714
2009 Milwaukee - Chairman's Award
2008 Milwaukee - Chariman's Award
2007 Cleveland - Kliener Perkens Buyers Caufield Entrepenureship, Engineering Insparation
2007 Milwaukee - Kliener Perkens Buyers Caufield Entrepeneurship, Website, Motorola Quality Underwriters Laboratory Safety
2006 Atlanta - Rookie Inspiration
2006 Cleveland - Rookie All-Star, Safety Runner-up
2006 Milwaukee - Rookie All-Star, Safety Runner-up
pi = 3.141592653589793238462643383279502884197169399715 10 ^_^
Unread 10-02-2008, 20:08
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: off board compressor
the KOP compressor, with the sensor and emergency release won't go past ~120psi. from there, you are allowed to fill the tanks to 120, but directly after the tanks you use the norgren(?) regulator (the black one, not the yellow one) to limit pressure to the cylinders and solenoids to 60 psi. also, why are you limiting your entire system to 60psi? you won't get very much working pressure. just fill the tanks to 120, then use the regulator (that you'll need anyways) to lower AFTER the tanks to 60. You'll now hold twice as much volume of air, just in case of an emergency. also, it doesn't hurt to have too much air...you may suddenly find a small leak and loose pressure slowly. believe me, always carry as much air as possible...
Unread 10-02-2008, 22:16
legotech25's Avatar
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
So, we don't need the 125psi regulator? We do use the 60psi regulator on our robot.
And yes, we really do want to limit the entire system to 60.
Unread 10-02-2008, 22:18
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Yes you need the 125 PSI emergency relief valve. Even if your entire system is at 60 PSI. Why do you want to limit your system to 60 PSI?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 10-02-2008, 22:24
legotech25's Avatar
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
60psi is all we need. So the regulator has to be on our robot? Or can it be offboard with our compressor?
Unread 10-02-2008, 22:25
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes You need to 125 PSI emergency relief valve on your robot if you have an offboard compressor. 60 PSI may be all you need but 120 won't hurt you.
Kevin Li
596 - Sciclones
Unread 10-02-2008, 22:28
legotech25's Avatar
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
Ok, thanks for your help. ^_^
Unread 11-02-2008, 19:47
legotech25's Avatar
Sarah
AKA: Sarah
FRC #1714 (TMCRC)
Wait a minute... the relief valve is what goes on the back of the compressor. Regulators are what I'm concerned with... so do we need a 120psi REGULATOR on the robot, or are we ok with just our 60psi regulator?
Unread 11-02-2008, 20:50
Imaginary Friend
AKA: Kevin Li
Team Role: Student
You don't need one of the regulators set to 120, but since your not using an on board compressor you need to have one of those things on the end of the compressor, on your pneumatic system. That is what the inspection checklist was refering to.
Kevin Li
596 - Sciclones
Unread 14-02-2008, 16:23
holty531 holty531 is offline
FRC #2441
Team Role: Electrical
holty531 is an unknown quantity at this point
so on your robot you need
125 emergency relief [the brass piece]
norgren electronic pressure sensore [one with the pwm cable]
main regulator to 60psi
flow valve
and then spike relays and such for the compressor offboard?
Unread 14-02-2008, 20:07
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes, you also need a pressure gauge that reads the pressure of your tanks.
Kevin Li
596 - Sciclones
Off robot air compressor sanddrag Rules/Strategy 52 11-01-2007 15:11
Off board processor? Joohoo Programming 11 22-05-2006 22:13
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
Air compressor never shuts off Carl Owenby Pneumatics 4 08-02-2003 23:34
