Go to Post While we're on the topic of games... there have to be some people who'd be interested in a good round of FIRST ROBOTICS!!!!!!!!!!!!!!!!!!! :p :yikes: :D :rolleyes: - Leav [more]
Unread 10-02-2008, 12:46
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
accelerometers and gyroscope to control arm?
Hello all. How can I use accelerometers to keep a robot's arm parallel to the ground? My initial thought process was to use the accelerometers to measure acceleration due to gravity, and if it felt any, then make the motors move the arm the opposite way. Does this seem about right? And can this be done with one accelerometer? Thanks in advance!
Unread 10-02-2008, 14:59
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: accelerometers and gyroscope to control arm?
Yes, this can be done, but you need to use a dual-axis accelerometer. The best mounting orientation is with the x and y axis at a fourty-five degree angle relative to the gravity vector (this is because the maximum rate of change of the accelerometer outputs is at this angle). Also, have a look at the atan2() function.
-Kevin
Kevin Watson
http://kevin.org
Unread 10-02-2008, 15:06
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Have you considered using a potentiometer instead? You could mount one on the pivot point on your arm, and use a PID loop to get it to be level by default. I would think this would be easier and more accurate than an accelerometer.
Unread 10-02-2008, 15:11
FRC #2429
I'm not sure if it's easier or more accurate, but I do know the accelerometer is a cooler solution .
-Kevin
Kevin Watson
http://kevin.org
Last edited by Kevin Watson : 10-02-2008 at 15:53. Reason: Fix my ambiguous posting.
Unread 10-02-2008, 15:21
Hazmatt's Avatar
AKA: Matt
We have been trying to mount a pot on the arm for a long time, and are finding it nearly impossible. I think we are going to have to go with the potentiometer though, after just realizing that the accelerometer is going to measure the acceleration of the entire robot also, if I set it up this way.
Unread 10-02-2008, 15:58
FRC #2429
It's more work, but you could use another accelerometer pair mounted perpendicular to the gravity vector to measure the 'bots acceleration due to movement and then use this information to correct the arms position.
-Kevin
Kevin Watson
http://kevin.org
Unread 10-02-2008, 16:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
If you can't mount a potentiometer on the actual rotation point on the arm there are other solutions. One would be mounting a shaft encoder somewhere else, and running a cable from it to the arm. As the arm moves, it will pull the cable and turn the encoder (essentially a spool or an inverse winch). You can then translate the rotations of the encoder into distance travelled into rotations of the arm.
Unread 10-02-2008, 20:04
Hazmatt's Avatar
AKA: Matt
Where can we get one of these encoders? Can't encoders only measure distance traveled, or can they measure direction also?
Unread 10-02-2008, 23:57
GUI GUI is offline
AKA: Gary
Quadrature shaft encoders can measure direction as well as distance. There are many suppliers for shaft encoders, pretty much any large electronics supplier will carry them, as well as some specialty companies.
Unread 11-02-2008, 00:20
cjtenny cjtenny is offline
FRC #2349
cjtenny is an unknown quantity at this point
Send a message via AIM to cjtenny
Hey,
I suggest using an accel & gyro so as to correct for the linear acceleration. Kinda like we did on the DIY Segway (http://web.mit.edu/first/segway/)... You can even view our code.
Then again it might not work as well for this.
It's like as Kevin suggested:
-Kevin
But since they don't give you two accelerometers, and they do give you 1 accel & 1 gyro... it's more KOP-compatible.
Although if anybody has an extra gyro, we need one, ours is broken and we want to use it. Just a heads up, as we've already posted in CD-swap. We can probably trade our accel for your gyro if you wanna do the 2-accel method.
Unread 11-02-2008, 08:46
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Why not use an absolute or even an incremental encoder to monitor the position of the arm? Actually, the potentiometer might be the simplest idea, but since I didn't see anything about an eoncoder...decided to mention it. On the other hand, if you're using ferrous metal gears on your arm you could use the GTSs too!
Accelerometer and Gyroscope freezing in EasyC Jennymcf Programming 0 01-02-2008 22:57
pic: 1625's arm control Aren_Hill Extra Discussion 9 15-10-2007 11:55
P.I.D. Control for the arm skibum2490 Programming 8 27-02-2007 11:21
Slave Control Arm aaronD341 Control System 1 26-04-2005 17:13
2-Segment Arm Control Orborde Programming 1 20-01-2005 01:40
