Re: Starting Config question
Now, I have known teams that were not allowed to power on to get into the box while on the field because they were barely outside it. You risk being in the same boat. That said, here is my suggestion: figure out a place you can mount a servo. The servo's arm (or attachments to it) should fit into a slot in your spring-hinged wheelie bar. The first thing that happens when the match starts is the servo moves the arm out of the slot. Now, the wall is the restraining item, but the robot is going into playing configuration. It isn't in starting position anymore. |
The only other way would be a pneumatic cylinder acting as a pin, if you already have pneumatics. (And, Vex servos are legal...) Edit:These threads might explain a bit better. Last edited by EricH : 11-02-2008 at 00:51. |
Thank you for the links to other threads the first one was especially helpful. The posts seem to give the Idea that it really depends on what inspector you get, so I think I will design a servo system, but try to get it sized first without it. Thanks for your deligent help EricH!
| [OCCRA]: Starting Ball question | Mike Martus | OCCRA Q&A | 0 | 04-10-2007 08:12 |
| Question about 3rd Tutorial ETA and FRC Modeler Motor Config | Ted155 | LabView and Data Acquisition | 2 | 21-01-2007 19:45 |
| Important question regarding starting position of balls in the BOT | Nimmy | Rules/Strategy | 2 | 12-02-2006 17:17 |
| Question on Starting Zone | MattD1Drift | Rules/Strategy | 3 | 13-01-2006 12:30 |
| Starting Position question | Ben Mitchell | Rules/Strategy | 5 | 11-01-2003 20:28 |
