Go to Post My students like to win, so I'll stick to enabling that. - sdcantrell56 [more]
Unread 11-02-2008, 03:05
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
Exclamation Please Help need quick answer :)
Hey everyone I hope everyone is having fun with their pneumatics as we are, but 3 really pressing questions here.
1) Where can I get spare/replacement for the SMC Double Solenoid Valve?
(Someone was working with a mallet near my pneumatics and well... the valve lost)
2) Is anyone willing to give or trade their valve(s) (should have received 2) we will pay for shipping.
3) I have saw some posts on this already, but my safety valve seems to also be set incorrectly. I have tested just a valve and some of the other safety features like the manual bleed and the sensor that goes to the robot interface in a controlled environment and have taken the pressure up to over 160 psi and the valve will still not budge I am submitting an official rule clarification to FIRST about the "do not modify rule" but want to here what everyone else has decided to do.
Thanks for the help,
Matthew
FRC1515
Unread 11-02-2008, 04:48
dtengineering's Avatar
AKA: Jason Brett
Re: Please Help need quick answer :)
I'd contact a local distributor:
http://www.smcusa.com/smcusa/contact.aspx?stateid=6
Or a nearby veteran team.
As for the safety valve, good on' ya' for putting in the Q&A. It is an undetectable fix that improves robot safety, but may as well get it approved by the GDC first. Either that or fix it under the watchful eye of a tech inspector at the competition... but it hardly makes sense to wait in order to make a safety improvement.
Jason
Unread 11-02-2008, 20:45
Clifford Clifford is offline
AKA: Clifford Harrison
FRC #2658
Clifford is an unknown quantity at this point
Perhaps I should have asked FIRST first?
Clifford Harrison, Alumni & Mentor
FRC Teams 2658 & 3749
FTC Team 5135
Unread 11-02-2008, 21:01
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
The inoperable pressure switch could be explained by wiring. Last year, we found the switch needs to be pulled up with a resistor (100K or so) in order to give a proper signal. This way, the controller sees 5V when the switch is open, and ground when it is closed.
Without the pullup, you get ground and high Z (read "floating")..which is an indeterminate state. The controller won't see a state change no matter what you do...so the tanks over charge. (NB: The switch doesn't turn off at exactly 120psi, but usually a little bit more.)
-JEE
Unread 11-02-2008, 21:41
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
The robot controller's digital pins are pulled high internally. In order to make the pressure switch work, you need only connect the ground and signal wires of the PWM cable to the two screws on the pressure switch. Cap the red +5v wire and don't connect it to anything.
Furthermore, the safety valve and pressure switch are two different things. The safety valve should let air out of the system when the pressure exceeds 125 PSI.
Unread 11-02-2008, 21:53
mlucas's Avatar
mlucas mlucas is offline
FRC #1516 (Grizzlies)
mlucas is an unknown quantity at this point
Send a message via AIM to mlucas
We have a bad pressure switch from a few years back, 2006 I believe, maybe you just got the duds? Be sure you have it connected to the Digital in and that your programming is correct. IF using EasyC, there is a block that all you do is input the digital input port, and the output for the spike...just my 2and a half cents
Team 1516-Grizzlies
Architect
CNC Machining, Electrical, Pneumatics, Drivetrain, and mostly GOPHER
Unread 11-02-2008, 23:36
DonRotolo's Avatar
Back to humble
FRC #0832
Safety Valve, not pressure switch.... I agree that the switch might be set for a little bit off from 120 PSI. The safety valve is passive and really should 'pop' off at 125 PSI or so.
After reading a few posts on the issue, I will have the team test the valve we're using, just for safety's sake. We've never had a problem, but the function of that valve is a critical parameter.
Don
Unread 11-02-2008, 23:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
we should test ours too....the pressure switch works fine, and we never tried to get the system over 115 psi.
Last year our safety valve was loose "out of the box" and we adjusted it and didn't think much of it. I guess it's rocket surgery, though....so if it's not working right, quickly ask for a replacement from FIRST?
Please Only Answer Questions if you know the Answer! Greg Needel General Forum 30 18-02-2010 12:26
Need an answer super quick, keyang motors!!! R.C. Motors 8 16-02-2008 18:40
Need a quick answer about grabber.... Steven S Technical Discussion 5 10-02-2008 17:02
Need a quick answer!!!! latonya Motors 1 09-02-2008 18:22
Need some quick help, ASME scholarship! Hymnson General Forum 2 25-02-2002 16:07
