Go to Post "Wow, smells like... physics" - Anna B. [more]
Unread 08-02-2008, 12:25
neonx neonx is offline
neonx is an unknown quantity at this point
Compressor mount
Whats the best way to mount the compressor to reduce vibration? It will be in the standerd orientation, i'm just looking for the safest way to brace it and connect it. Also, are the screws that come with it good enough to hold it? [ the ones that are on the dampners ]
Unread 08-02-2008, 12:36
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Compressor mount
We have found that the supplied screws are prone to failures. We're considering using a bolt with springs or rubber grommets underneath the compressor legs slightly compressed.
Unread 08-02-2008, 14:39
johnnysanchez johnnysanchez is offline
FRC #2582
johnnysanchez is an unknown quantity at this point
we use a mouse pad
Unread 08-02-2008, 14:49
I'm just having trouble finding nuts and screws to fit the mounts. The stock screws are so tiny!
Unread 11-02-2008, 08:50
Generator of Entropy
FRC #2973 (The Mad Rockers)
I'm not doubting your observation, but we have always used the supplied damper screws and have never had a problem during use (we have torn them during installation by over zealous torquing). I'd like to hear from other teams who have used them and see what they have experienced - it's a pretty standard shock mount system.
The threads in the compressor base are #8-32 if you want to use a screw and some other damping material (grommet and mouse pad are both good ideas.). You can buy additional mounts on McMaster.com
Unread 11-02-2008, 08:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We use the provided rubber insulators, with plain 8-32 nuts, and have not had any problems. Be sure to leave about 1/2" clearance around the compressor to allow it to move as needed, and leave slack in the connecting tubing and wiring.
Unread 11-02-2008, 08:59
Plain nuts is the key - we tore one of ours trying to put on a lock nut (it took too much torque to put it on. I recommend double nutting to lock the nut because of all the vibration.
Unread 11-02-2008, 09:56
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Our team bought new vibration dampers from McMaster-Carr, the ones supplied are too flimsy and can tear when just tension applied from ones fingers is applied to it. As for orientation, any way you can fit it on the bot is good, which is hard because of the triangular base...
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
compressor stephenthe1 Pneumatics 3 11-01-2005 08:29
compressor Greg Needel General Forum 2 14-02-2003 07:50
Compressor TwoEdge47 Pneumatics 5 04-02-2003 22:41
compressor? BBFIRSTCHICK Pneumatics 11 22-01-2003 07:12
