Go to Post FIRST is not all about the competitions. FIRST is about what you learn to get to wherever you got to, whether that be first seed or last. - StephLee [more]
Unread 09-02-2008, 11:45
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
FRC #2220 (Blue Twilight)
sfs is an unknown quantity at this point
Color sensors
Is anyone using color sensors? Specifically, we were looking for information on the QS18VP6D which has 4 pins, 2 of which are for power, 2 for sensing color.
Unread 11-02-2008, 04:33
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
Re: Color sensors
I believe they are mandatory due to R66 in Section 8.
Unread 11-02-2008, 06:46
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Color sensors
R66 refers to the color LED Flasher not to color sensors.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 11-02-2008, 09:08
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Color sensors
What are you looking for? You can google the sensor and get the information.
The range is 450mm - 17.8 inches
Unread 11-02-2008, 09:27
Tom Line's Avatar
Re: Color sensors
FYI - these are "trainable" sensors. You train them to the color you want.
See the wiring diagram in the .pdf sheet? Basically when it sees the color you've trained it to, it outputs 10-30V off one pin. When it doesn't, it outputs 10-30V off another (the pin shown normally closed in the wiring diagram). Be aware this sensor is for at least a 10V system. You'd be advised to do a step-up circuit for the backup batter to get it to 12V because your robot battery will likely dip below 10 during high-draw periods.
Color Sensors wilsonmw04 Electrical 3 23-01-2008 11:50
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Color? neilcooper Technical Discussion 2 11-01-2005 16:58
how well do the sensors pick up color? Kyle Technical Discussion 15 10-01-2005 12:31
