Go to Post you know you are addicted to first when u crave sprockets for breakfast! - Jones571 [more]
Unread 11-02-2008, 09:58
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Modification of the SMC Valve?
Does anyone know if it is considered a modification or legal to drill the mounting holes in the SMC valve base out making them slightly larger in order to tap them for an 8-32 screw to mount to the robot?
Unread 11-02-2008, 10:03
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: Modification of the SMC Valve?
I didn't see anything in the Pnumatics manual, try checking Section 8 in the Rules.
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 11-02-2008, 10:06
AKA: Jacob Miner
Here is the rule that I found.
<R92> Pneumatic components supplied in the Kit Of Parts (compressor, regulators, pressure
switches, cylinders, valves, fittings, tubing, etc.) can not be modified except as follows:
 The tubing may be cut.
 The wiring for the valves and pressure switch may be modified as necessary to interface
with the control system.
 Mounting and connecting pneumatics components using the pre-existing threads, mounting
brackets, etc., is not considered a modification of the components. Removing the pin from
the rear of an air cylinder is allowed as long as the cylinder itself is not modified.
Do not, for example, file, machine, or abrasively remove any part of an air cylinder. Consider
pneumatic components sacred. They must remain in “out of the shipping box” condition.
Unread 11-02-2008, 10:09
AKA: Jacob Miner
I also found this in the inspection checklist. It should be legal.
430
No disallowed pneumatic component mods. Allowed mods include – cutting tubing, wiring for valves and pressure switch to accommodate interfacing to rest of system, the rear pin of air cylinders can be removed.
Unread 11-02-2008, 10:44
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Read Rule <R92> carefully:
<R92> Pneumatic components supplied in the Kit Of Parts (compressor, regulators, pressure switches, cylinders, valves, fittings, tubing, etc.) can not be modified except as follows:
• The tubing may be cut.
• The wiring for the valves and pressure switch may be modified as necessary to interface with the control system.
• Mounting and connecting pneumatics components using the pre-existing threads, mounting brackets, etc., is not considered a modification of the components. Removing the pin from the rear of an air cylinder is allowed as long as the cylinder itself is not modified.
Do not, for example, file, machine, or abrasively remove any part of an air cylinder. Consider pneumatic components sacred. They must remain in “out of the shipping box” condition.
Draw your own conclusions. If there is any question at all, then please get confirmation one way or the other from the FIRST Q&A System.
None of us want to see any Robots rejected during inspection. If there is a problem, the inspector won't listen if you say "well, somebody on CD said it was OK..." (particularly if that information is just flat out wrong)
-dave
Unread 11-02-2008, 10:58
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Now that Dave has given the unofficial answer, (official answers ONLY come from the GDC via the Q&A system), you still need to know a way to mount your valves.
What we have done this year is used "zip ties/ty-wraps" to attach the valves to the mounting board. We drill for holes in the mounting board and then use either a crisscross or a straight across wrap of of the valve.
Unread 12-02-2008, 10:12
AKA: Michael
Yeah thats how I did it last year, but this year we wanted everything to be secure and all, but now knowing this, I am going to shoot myself for not asking the GDC because I think the valves have already been drilled and tapped...
God this season is starting to wear on me...
thanks for the help all
Unread 12-02-2008, 12:49
dtengineering's Avatar
AKA: Jason Brett
4-40 machine screws fit quite nicely through the SMC valve mount holes. Why not try that and see how it looks.
Jason
Unread 13-02-2008, 08:03
AKA: Michael
Jason
Yes, yes they do fit quite nicely so we will end up using them...
In the rush of the last week we just happened to find 4-40 screws and said wow, it works......
thanks for the help
Using SMC Single Selenoid Valve from last year? Sachiel7 Pneumatics 3 20-01-2005 21:31
SMC Double Action Valve. Josh Hambright Pneumatics 2 14-02-2003 10:24
SMC valve leak? inwoodraider Pneumatics 1 02-02-2003 01:04
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
