Go to Post You win Worlds by innovation. You win Worlds by determination. You win Worlds by engineering a robot so solid, that it successfully completes the game. - Zach O [more]
Unread 11-02-2008, 14:04
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Electrical Wiring Losses
On our bot, we have the +12 volt wire going from the battery, through the reset-able breaker, to the distribution rail. From there, it goes in one side of a maxi block. A new wire comes out the other side of the maxi block and goes to the small black fuse panel terminal, then a third wires comes off the small fuse panel terminal and goes to our last maxi block.
Are we unknowingly introducing a high amount of transmission resistance by having the multiple connections in our wire run, compared to running individual wires from locations on the distribution block and going directly to each component?
Electrical wiring TERTOLA Electrical 5 16-01-2008 16:22
Basic Electrical Wiring Alienvin Electrical 2 18-01-2005 23:24
Electrical Schematic/ Wiring diagram sanddrag Electrical 9 11-01-2005 12:51
Electrical wiring layout sheet George T Electrical 1 11-02-2003 18:20
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
