Go to Post I pumped my fist to cheer - but since I was a ref at the time it looked like I signaled a red foul... - Tom Ore [more]
Unread 08-02-2008, 09:17
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
VICTOR ISSUES
Our victors have been suddenly stopped working in the sense of the PWM or digital part of them. They still have power but occasionally one stops working. We have lost 3 over the last few week. Can anybody help? Thanks!!!!
Matt
Unread 08-02-2008, 09:24
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: VICTOR ISSUES
Check and make sure that all of the screws in the Victors are all the same and the original ones that came with the victors. Smaller screws will short out your victors.
The power from the Maxi block should go into the V+ and V- ends. The motors should be connected to the M+ and M-. Make sure they are connected correctly.
Good luck,
Jacob
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 08-02-2008, 09:59
DaveF DaveF is offline
DaveF has a spectacular aura aboutDaveF has a spectacular aura aboutDaveF has a spectacular aura about
Re: VICTOR ISSUES
Jacob,
Your post had me doubting myself, so I went and checked. The +12 V connection goes to the fuse block. The gnd terminal of the Victor goes to your common ground on the Rockwell Block. The +M and -M terminals connect to the motor, not the the Maxi Block.
Not sure what would happen if you connected a Victor backwards, but it certainly would not pass inspection if it lasted that long.
Unread 08-02-2008, 10:07
Re: VICTOR ISSUES
What does the LED show when the Victor "stops working"? If it's blinking yellow, it means it's not recognizing a pwm signal. One trivial cause of that problem is the pwm cable not being plugged in fully.
Unread 08-02-2008, 10:26
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: VICTOR ISSUES
Quoted for truth!
No matter how hard we try, at least a few times every year, a few of our PWM cables don't get plugged into the Victors properly.
Pull out the PWM cables from any Victors that do nothing but blink orange. Check to see if the pins are bent. Some people don't even notice, but often all the pins are bent in the same direction slightly. That means you missed!
Straighten them out and try again! PWMs should take very little force to insert. If you feel resistance halfway while inserting them, you've missed!
Try again...
then try again...
and then again =)
Unread 08-02-2008, 13:24
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: VICTOR ISSUES
Originally Posted by DaveF View Post
Jacob,
DO NOT connect the M+ and M- terminals to the terminal block, or any power source. The "M" means they connect to motors.
The power from the Maxi block should go into the M+ and M- ends. The motors should be connected to the V+ and V-. Make sure they are connected correctly.
Good luck,
Jacob
Wiring a Victor backwards is probably the easiest way to burn out a Victor. Do not attempt this.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 08-02-2008, 16:18
AKA: Jacob Miner
Re: VICTOR ISSUES
I have corrected my post on this thread. I am extremely sorry for the mistake. Thank you for noticing.
Jacob
Unread 11-02-2008, 14:14
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: VICTOR ISSUES
Originally Posted by SlimBoJones View Post
Quoted for truth!
Try again...
then try again...
and then again =)
An easy solution to this problem is to put a dot of hot glue on the pwm once you get it in and reading correctly. It peels off instantly if you need to take it out, but in the mean time you don't have to deal with vibration shaking your PWM's loose.
Unread 11-02-2008, 15:16
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: VICTOR ISSUES
one thing that we have started doing with out PWM wires that go to everything is to shave down some of the plastic on the end that plugs into the Victors. This allows for less friction and more exposure of the terminals.
Unread 11-02-2008, 16:24
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: VICTOR ISSUES
We use a fine Dremel bit and very carefully remove the "anti-pwm plug nub" that runs along the inside of the Victor socket. Vacuum it out then hot glue the cable into place.
Unread 11-02-2008, 20:32
bman's Avatar
bman bman is offline
FRC #0548
bman is an unknown quantity at this point
Re: VICTOR ISSUES
You guys are lucky that your victors are just not working, two of ours blew up!
Unread 11-02-2008, 22:01
longrange longrange is offline
FRC #1070 (Royal Robotrons)
longrange is an unknown quantity at this point
Re: VICTOR ISSUES
Always cover the victors when cutting/filing the robot. We always seam to destroy some with metal chips at regonals when modifying the robot.
Unread 15-02-2008, 18:47
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: VICTOR ISSUES
I think we had the same issue with one of our Victors. We had it connected to a FP motor, and it was working fine for 3 weeks, and then, one day while driving, it decided to stop working. The LED would just blink as if it had no signal. I verified the PWM cable was fully seated and that it was getting a signal, and later replaced it with an old 884 Victor from a previous year. I thought it was strange that it just went out. No magic smoke, it was not overheating, no drill shavings, it just lost the signal.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Victor 884 Issues BHS Bucs Electrical 3 01-02-2008 15:10
Programming Issues etdeshon Programming 5 21-01-2008 17:59
Issues with non working victor constant orange led dani190 Control System 10 21-12-2007 22:32
Victor 884 Brake/Coast Issues sciguy125 Control System 23 23-01-2005 14:46
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
