Go to Post By the way why do all american's spell Colour wrong?!?!?!?!?!?!?!? - akoscielski3 [more]
Unread 11-02-2008, 14:51
huskyrobotics huskyrobotics is offline
FRC #0848
huskyrobotics will become famous soon enoughhuskyrobotics will become famous soon enough
Red face Programming 4 cim motors
We are essentially a rookie team every year we compete and our new programmer is having trouble with getting all four cims to work. We are using mplab and two joysticks. We are in search of any code and would also like to know if the PWM numbers matter...is 1-4 better than 13-16? Thanks
Unread 11-02-2008, 15:06
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: Programming 4 cim motors
although i do not have any code on hand that I can send you, PWM numbers are only a way of identifying the ports and have nothing different about how they are wired in the board or how the react when you send a command to them in programming.
Unread 11-02-2008, 15:11
If you're putting two CIMs on the same gearbox, you can use a pwm Y cable to control both of their Victors from the same pwm output. Then just program it as if it were one motor.
Using pwm outputs 13-16 is fine as long as you don't have a lot of interrupt sources active (from shaft encoders, gear tooth sensors, fancy timers, and the like). If you have added anything like that, they'll act jittery and occasionally even make motors run when you want them to be stopped. You can avoid those outputs, or you can install Kevin Watson's fancy pwm support library to tame them.
Unread 11-02-2008, 15:13
FRC #0848
Thanks for the replies. Where can I get a pwm y cable?
Unread 11-02-2008, 15:16
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You should have two of them in your Kit Of Parts.
they have the black/yellow/red wires.
Unread 11-02-2008, 15:19
FRC #0848
Thank you!!!
CIM motors Spencer E. Technical Discussion 1 13-01-2008 11:07
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Cim motors trhgammer Motors 1 15-02-2006 12:31
CIM Motors UlTiMaTeP Motors 13 10-01-2006 14:48
CIM Motors rocky ali Motors 2 24-09-2005 17:55
