Go to Post gears won't care if theyre running underwater... the electronics will ;) - Cory [more]
Unread 11-02-2008, 14:43
cstringer cstringer is offline
None #2339
cstringer is an unknown quantity at this point
Electroncic's Board?
we are a rookie team and we are looking for other team's input on our electronic's board
Name:	circuit board.jpg
Unread 11-02-2008, 14:50
sarcasticmadnes sarcasticmadnes is offline
AKA: Christine Chen
FRC #0115 (Monta Vista Robotics Team)
sarcasticmadnes will become famous soon enough
Send a message via AIM to sarcasticmadnes
Re: Electroncic's Board?
The crimp on the red wire to the main circuit breaker looks like it's not insulated, so I would either wrap electrical tape around it or put some heat shrink on it. Also the crimps on the breaker panel need heat shrink as do the crimps on the spikes. Otherwise, it looks okay. Good luck!
Unread 11-02-2008, 14:52
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
Shouldn't the ground wires coming off the 40amp Victors be going to the power distribution panel and not that fuse panel?
FRC78: 2010-Present
FRC121: 2002-2009
Unread 11-02-2008, 14:54
None #2339
thank you we are doing that as we type
Unread 11-02-2008, 15:01
None #2339
Not sure on the grounding? Comments?
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I'm not quite sure what is going on with the red wires connecting to your main breaker and the right side of the red section of the Rockwell block. Is that a single wire? If so, can you make it shorter? Either way, you should get some electrical tape on the exposed metal parts of that lug to make sure nothing touches it while its energized.
It's generally preferred that the negative leads from the high-current Victors be connected to the Rockwell block rather than to the ATC panel as this reduces the loss.
I can't tell whether you've connected the fan wires for the Victors, but if you haven't, you should. The preferred connection method is to put lugs on them and then connect them to the V+ and V- terminals of the Victors they go with (on the same screw as the main power connections). That way the Victors will have cooling any time they are drawing current. It's also acceptable to gang them together and give them their own breaker.
It doesn't look like you've given yourself a lot of room to get your motor leads out of the Victors on the left side.
All that aside, it still looks better than the electronics board we used as rookies.
Unread 11-02-2008, 15:13
None #2339
Cool Re: Electroncic's Board?
ALRIGHT WE'RE GOOD!! THANKS FOR YOUR HELP.
FROM TEAM 2339
Remote board Mike.Allen Electrical 5 31-01-2008 15:34
IR board joshuamorris Electrical 2 12-01-2008 19:43
IR Board? Pavan Dave Rules/Strategy 3 06-01-2008 19:10
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
