Go to Post I think all drivers will be required to wear tights! - Mike Martus [more]
Unread 11-02-2008, 14:46
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Bumping resets bot
Hey there...
We are currently testing our code, everything in Hybrid seems to be working as planned, but one thing...
Every time we bump into something the whole mode simple resets itself and auto starts from point 0.
anyone knows what should we do?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 11-02-2008, 14:48
Bharat Nain's Avatar
Re: Bumping resets bot
Are you sure all your wiring is tight? It sounds like your robot controller is being reset and loose connections tend to do that.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 11-02-2008, 14:54
Tottanka's Avatar
AKA: Liron Gurvitz
We thought so too, but apparently it's not it.
Though the bumping is anything but gentle...so will be the case in the game...
We don't want our hybrid restarting in the game now, don't we =]
Could it have anything to do with the gyro ?
Unread 11-02-2008, 15:06
It certainly could but we cannot help you without seeing your code. Just about anything is possible in programming.
-= Bharat Nain =-
Unread 11-02-2008, 15:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You could try disconnecting or disabling the gyro and see what happens...
Unread 11-02-2008, 15:48
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Last year we had to have a delay to initialize the gyro after power on. If we didn't, we'd get extremely irradic behavior out of it. If you think it's gyro related, you could try this.
Can you tell if the whole RC is being reset? Do you see any indicator lights on the OI that say the RC lost power, reset, etc (don't remember the exact LED labels atm)?
GitHub
Unread 11-02-2008, 16:47
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Another item to consider - if you're bumping, does that also mean that your motors are temporarily stalling? If so, you might be resetting your RC due to voltage dips if your battery is a bit low on charge.
Russ
Bumping from underneath idahorobot Rules/Strategy 10 10-01-2008 22:27
info on 997 bot or 254 bot please! u2andllamasohmy Motors 16 11-11-2007 23:33
RC randomly resets or goes into program mode Tom Bottiglieri Programming 4 15-02-2006 23:32
RC resets itself when robot tries to move cheesinglee Electrical 28 04-07-2003 21:59
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
