Go to Post Do I think the bar is too high? I think impossible dreams and lofty goals are a key part of FIRST; the "top" being extremely far away only pushes people farther. - Chris is me [more]
Unread 11-02-2008, 08:56
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
potentiometer typo?
Hi, I've made some modifications to a steering wheel and pedal set by replacing the 10K pots with 100K pots. This was done according to the Operator Interface reference guide. On page 5, they show a wiring diagram for a typical 100K potentiometer. The way I've used pots in the past are as variable voltage dividers. By taking a look at the wiring diagram, the third pin is labeled to have no connection. If this is true, then the pot would act as a variable resistor instead of as a voltage divider. I was wondering if this is a typo, or if I should disconnect the ground lines of the pots in the steering wheel and pedal set.
Thanks,
Windell
#2477
Unread 11-02-2008, 09:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: potentiometer typo?
Apparently the OI is designed to have the pot wired exactly as shown in the diagram...with only one end connected. This is a safety feature that will allow the OI to detect when the joystick cable is pulled out, and shut off the robot drive.
I've been advised by a couple knowledgeable people here to wire it as shown in the diagram when I asked the same question.
Unread 11-02-2008, 18:04
FRC #2477
Thank you very much, squirrel! I was told that the joysticks that came with the KoPs are wired like voltage dividers? Is this a problem? Would voltage dividers work fine?
Unread 11-02-2008, 18:42
Gdeaver Gdeaver is offline
FRC #1640
IFI completes the voltage divider internaly to the OI. This allows them to determine if the analog port is used.
Unread 12-02-2008, 01:12
Voltage dividers will work, but not perfectly. You need to put a series resistance in the ground side to offset the voltage so the OI can read the full range of values from the potentiometer. I think the lower limit of usable voltage into the OI is about 600 millivolts.
I apologize for not being more specific, but I never actually did this. I'm just remembering a discussion from some time last year.
Potentiometer fezkazi Electrical 3 24-01-2007 13:29
Word of Warning: Google Typo = Bad Clark Gilbert Chit-Chat 15 02-05-2005 11:38
coding a potentiometer incognito_NICK Programming 5 14-02-2005 15:56
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Woodie Flowers Award typo! archiver 2001 2 24-06-2002 01:26
