Go to Post Mentor-built (adj.): A term describing a robot that is better than your own, and / or a robot with paint on it. - Chris is me [more]
Unread 11-02-2008, 17:56
BeyondRamo's Avatar
BeyondRamo BeyondRamo is offline
AKA: Omar
FRC #0334 (Tech Engineers)
Team Role: Electrical
BeyondRamo is an unknown quantity at this point
Exclamation Bending the Bumpers
Currently our team has a circular robot. At this point we have two ideas of how to attach the bumpers: 1) simply bending the 3/4" plywood into circular arcs which we will fasten to the robot OR 2) taking circular arcs out of the plywood and then stacking them up to get to 5", although 3/4 does not not go evenly into 5, we are still wondering if they would let that little offset go or not. If anyone has any other suggestions of as to how we can even create circular bumpers please let us know.
Unread 11-02-2008, 17:58
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Bending the Bumpers
some of the past robots that were circular (don't remember the specific #'s) just did about 8 or so pieces of bumpers. it looked cool and covered their circle robot. hope that helps.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 11-02-2008, 18:02
Go with option #1. Here's why. Or you could segment the bumpers.
Unread 11-02-2008, 18:11
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Option 1 is definitely legal per the Q&A response EricH cited, and is what I would recommend.
I don't think option 2 would pass inspection, based on this answer to a similar question: http://forums.usfirst.org/showthread.php?t=8316
Unread 12-02-2008, 15:09
BeyondRamo's Avatar
AKA: Omar
Thanks for the feedback, looks like we are going to bend the wood segments and attach them each seperatly, thanks again for the help.
Unread 12-02-2008, 17:14
DonRotolo's Avatar
Back to humble
FRC #0832
I suspect you will be unsuccessful in bending 3/4" plywood. Even if you were able to steam it long enough to become flexible, it's not really able to be bent like that.
You can make 3/4" plywood out of several thicknesses of, say, 1/4" plywood (and glue) - which can be bent. Or better still, literally make your own plywood out of 1/8" thick slices of wood, called Veneer. That doesn't need much to bend.
Google wood bending for some ideas.
Don
Unread 12-02-2008, 17:17
Umm... Don, I suggest checking Q&A on making your own plywood, particularly the post vhcook linked to.
Unread 12-02-2008, 18:39
GaryVoshol's Avatar
Cogito ergo arbitro
You can make 3/4" plywood out of several thicknesses of, say, 1/4" plywood (and glue) ...
But you can't use that homemade plywood on a FRC robot, as Eric references:
I didn't want to leave a dangling "look it up" here - not when a team is told something exactly opposite the rule.
(since 2004)
Bending Aluminum Tubing? Kims Robot Technical Discussion 11 08-02-2008 03:53
The Bumpers latonya General Forum 6 07-02-2008 21:45
Bending Metal Jeremiah Johnson FIRST Tech Challenge 2 01-05-2006 01:15
bending bumpers CharlieWilken Technical Discussion 3 19-01-2006 10:02
bending parts foobert FIRST Tech Challenge 4 15-01-2006 13:17
