Go to Post The shirts. The buttons. The capes. That feeling you get when you first glimpse the arena and all the empty pits, and the only thing is promise. When the last bit of confetti has fallen, and nobody leaves the field. We are fortunate. - Taylor [more]
Unread 11-02-2008, 21:38
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
Piston Pin
Can you take the back mounting pin out of the pistons and replace them?
I know the rules say not to modify the pistons at all, but taking the pin to mount the piston illegal?
Unread 11-02-2008, 21:39
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Piston Pin
Yes you may take the pin out.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
FRC #0870
Re: Piston Pin
thank you very much.
Unread 11-02-2008, 21:41
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Piston Pin
Rule reference for you...
<R92> Pneumatic components supplied in the Kit Of Parts (compressor, regulators, pressure switches, cylinders, valves, fittings, tubing, etc.) can not be modified except as follows:
 The tubing may be cut.
 The wiring for the valves and pressure switch may be modified as necessary to interface with the control system.
 Mounting and connecting pneumatics components using the pre-existing threads, mounting brackets, etc., is not considered a modification of the components. Removing the pin from the rear of an air cylinder is allowed as long as the cylinder itself is not modified.
Do not, for example, file, machine, or abrasively remove any part of an air cylinder. Consider pneumatic components sacred. They must remain in “out of the shipping box” condition.
Pause a piston? cliff451 Pneumatics 6 23-01-2008 20:52
Piston question Spiffizzle Pneumatics 3 10-01-2007 21:17
Piston throw Alex N. Pneumatics 2 21-01-2004 21:19
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
