Go to Post When you score a Supercell on your own alliance it has a tendency to sway a match... - EricLeifermann [more]
Unread 11-02-2008, 22:21
Team2441 Team2441 is offline
AKA: Danielle
FRC #2441 (Team 2441)
Team2441 is an unknown quantity at this point
HELP EMERGENCY WITH FISHERPRICE MOTORS
our team as not expecting to use the fisherprice motors and we are having difficulties finding information on how to mount them to the KOP gearboxes please help
Unread 11-02-2008, 22:42
CraigHickman
Posts: n/a
Re: HELP EMERGENCY WITH FISHERPRICE MOTORS
http://andymark.biz/am-0002.html
Hope it gets to you in time.
Unread 11-02-2008, 22:43
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
If you mean attaching it to the AM tough box, It is not a simple task. If you are planning on using 1 CIM motor and 1 FP you need a additional gearbox to change its output. AndyMark makes a good one.. You must use an adapter to change the output RPM's of the FP. You cannot just bolt on the FP.
If you mean attaching it to the black plastic gearbox, there are holes for mounting screws on the input end (The hole. not the white ring). I believe they are 4-40 screws. to mount it you simple have to put the screw through and screw the motor in.
Unread 11-02-2008, 22:45
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
In the SMC box of the black tote, there should've been a small packet of screws with blue thread sealer on them. To attach the motors, you simply insert them into the black FP gearboxes, put the screws through the holes on the opposite side and tighten them a reasonable amount.
Unread 16-02-2008, 22:34
AKA: Danielle
Smile Re: HELP EMERGENCY WITH FISHERPRICE MOTORS
Thank you so much for all of the help.
Unread 16-02-2008, 22:42
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
Agreed if you can afford them, use them. It never hurts to harness some AM power in your bot, I know we do every year.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
FisherPrice Motors can be purchased where? robotguru1717 Motors 2 30-01-2007 00:24
Emergency:Streamline help Pat Roche Inventor 4 14-03-2004 10:40
Some help with motors Bharat Nain Technical Discussion 2 05-03-2004 19:29
Emergency Team 25 Needs Help Keith Chester Technical Discussion 19 25-02-2004 21:35
Emergency! Need Help With Ir Sensors magical hands Programming 16 19-02-2004 23:34
