Hooking up a custom OI panel
We are planning a panel of switches for our pneumatics, but might have a problem. I found the pinout guide at http://www.chiefdelphi.com/media/photos/26381 and it looks like there are only 4 digital outputs; we are needing eight. We could hook up a second serial connector, but I was wondering if the analog outputs could be used. I'll admit I am mostly a programming guy, so this may be an incredibly stupid question.
I know the analog outputs have a range of 0-255. If we hooked up our on off switch to them, would they return 0 or 255, depending on the switch position, or would they fry our OI? I'm hoping I can be lazy without killing anything. |
Re: Hooking up a custom OI panel
If you look at the IFI OI guide on www.ifirobotics.com, they show the full pinouts of those ports. There are on ports 3 and 4 I believe, passthroughs of the 4 buttons on port 1/2. Thusly if you werent using the buttons on your p1 and p2 joys, you could use the passthroughs. I would just be a little worried about accidentally activating them from p1 (ie. driver accidentally clicks the trigger on the drive joy) Though that is easily remedied through a simple "modification" to the joy. |
I'm pretty sure you mean analog versus digital inputs if you're talking about the OI. As for using the analog inputs with on-off switches, there shouldn't be anything wrong with that, certainly not on the OI-frying level. If you hooked a potentiometer up to that same analog input, you'd just be varying the voltage between ground and +5 anyway, so doing it with a toggle switch is no different. I think it makes sense and would allow you to use only one cable. The one caution I do have is that on the programming side, you should probably do input < 127 means 0, input >= 127 means 1, lest fluctuations in voltage cause the analog value to read a 1 or 2 instead of 0 (and likewise with the 255 end). |
Thank you for your responses. I figured it might be a little to weird to program, but thank you for confirming that it would work.
| Hooking up a backup battery | neoshaakti | Control System | 7 | 26-01-2008 22:09 |
| hooking up potentiometers | chippermonky | Programming | 1 | 05-02-2007 20:04 |
| Hooking up 2 Servos | kutty18 | Programming | 7 | 04-02-2005 09:26 |
| Problems hooking up a joystick to edubot | Salik Syed | Programming | 2 | 24-03-2004 23:56 |
| hooking up sensors to controller? | Oakridege_665 | Technical Discussion | 5 | 21-01-2002 14:55 |
