Go to Post Gracious Professionalism at its finest - Competing like CRAZY on the field, then working together like professionals off the field to make these events the best they can be for everyone involved. - Stu Bloom [more]
Unread 12-02-2008, 09:53
AKA: Brad
#0190 ( Gompei and the Herd)
Re: gyro not working
Originally Posted by johnsmith11111 View Post
I'm programming in easy-C with a gyro. I had a simple autonomous function initialize the gyro, wait 1200 milliseconds, start the gyro, then go to a loop where it got the gyro value and printed it to screen. No matter how I turned the gyro, it only gave a readout of zero. I then downloaded the same code but without the 1.2 second wait, and it worked fine. When I try to embed this code into the rest of my autonomous code, it does not work. Can anyone help me?
That's a little confusing. The Initialize routine actually waits until the robot has been turned on for a second (settling time for vibration), then it does a one second calibration where it computes the average non-moving value. So you shouldn't need to 1.2 second wait.
I'm not sure why adding it changes anything, but you can look at a pretty simple sample program here that does work:
http://users.wpi.edu/~bamiller/WPILib/Samples.html
Please let us know if you find a bug in something that is causing your problem.
Brad Miller
Robotics Resource Center
Subscriptions not working? Jeff Waegelin CD Forum Support 2 07-02-2007 14:11
Gyro not working in Autonomous? kaszeta Programming 7 11-02-2006 01:28
CMUCam not working Inverted Programming 10 04-02-2005 19:32
Radios not working... E Jones 234 Control System 3 21-01-2005 21:58
Radios not working... E Jones 234 Electrical 3 21-01-2005 21:58
