Go to Post The major items of FIRST are still what they always were.....understand the game, build a reliable quality machine to play it, train you drivers to use it to its full potential. If you do these things, you can win with or without any specific machine feature. - Jim Zondag [more]
Unread 12-02-2008, 10:10
sonnguyen sonnguyen is offline
FRC #1405
sonnguyen is an unknown quantity at this point
Problem with p18cxxx.h and stdio.h
C:\2008\sensor_30\ifi_frc.h:31:Error [1027] unable to locate 'p18cxxx.h'
C:\2008\sensor_30\serial_ports.h:48:Error [1027] unable to locate 'stdio.h'
I got this problem when I tried to compile the codes. I used the orignial code and there was no such files like those two.
How can I solve this problem ?
Unread 12-02-2008, 10:42
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: Problem with p18cxxx.h and stdio.h
Check default location of include files in MPLAB.
Project->Build Options->Project, make sure Include Path points to the location of mcc18\h. Of course this assumes that you are using MPLAB - other build environments are probably different.
The mcc18 on my system is located on E:\ drive, but most systems have the compiler suite on C:\ drive. You can use the browse function to locate the mcc18\h directory.
Problem with easy c pro and mechanum wheels pbrules15 Programming 9 03-02-2007 20:38
Help! unable to locate 'p18cxxx.h' ducttapehaxor Programming 1 24-01-2006 16:13
stdio.h complilation error reilly Programming 4 01-02-2005 20:49
Problem with reading and writing EEPROM DKolberg Programming 4 16-03-2004 19:29
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
