Re: problem with printing float
Here's an another alternative with just a little manipulation. You can turn something such as this into a utility function.
#define ACCURACY 1000 //How many decimal places are important to you
float f;
int i, i2; // Might need to be longs if you have a lot of significant digits
f = 245.56;
/* Print float value */
i = (int) f;
i2 = (int) ((f-i)*ACCURACY);
printf("f = %d.%03d \r", i, i2); //e.g., f = 245.559
| printing FLOAT data type on the terminal window | razer | Programming | 14 | 05-02-2007 08:55 |
| Robots that float | boy_scout72688 | Rules/Strategy | 31 | 15-01-2007 22:18 |
| Float Design | i like dirt | Technical Discussion | 3 | 13-09-2006 00:21 |
| Float in MPLAB | capenga | Programming | 1 | 18-02-2005 06:44 |
| Problem with communicating with STAMP through serial port | Skabana159 | Technical Discussion | 2 | 06-02-2003 21:10 |
