Switching between Hybrid and User-Controlled
Being a rookie team, we were wondering...
Do we have to program the detector to change between autonomous and user-controlled into the code ourselves?? Or will we not need to. Also, what do you do to test both hybrid and user-controlled? Thank you. |
Re: Switching between Hybrid and User-Controlled
I'm not sure about the programming side of things, though. |
no, you don't have to do it yourself.
There are 2 ways to practice hybrid. 1) build an autonomous box that connects to the Comp port of the OI and switches between auto, teleop and disable. Instructions are at the ifi website. 2) change your team number to 0000 and run the robot, it switches to auto... |
We tried 0000 but it just stood there. If you look on the schematics, its just 2 pins in the competition serial port that need to be connected. The top left and the top one under the 15 (i think? or the fourth one from topleft...ill get back to you...in programming class). then when you want autonomousto stop unplug the wire.
| EDU-MINI RC Solenoid Switching times and Delay time? | Generalx5 | Technical Discussion | 0 | 25-01-2007 01:32 |
| Autonomous and user controlled mode switching | sparrowkc | Electrical | 3 | 15-01-2007 13:15 |
| interference between wires and connectors | Dan Zollman | Inventor | 5 | 18-12-2006 15:11 |
| Relationship between wheel type and power | Nitroxextreme | Technical Discussion | 3 | 13-01-2006 21:30 |
| Toggle between in and out (Pneumatics) | RAWdealer59 | Programming | 7 | 17-02-2003 11:32 |
