Go to Post Hey, those kind of thoughts lead to thick rulebooks!;) - David Brinza [more]
  #46   Spotlight this post!
Unread 16-01-2008, 08:47
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: SONAR Sensor Software Driver
Okay, now I'm getting a little annoyed. It's time to get this sonar working once and for all!
We got Qbranch's code working with our 2006 robot and code. We haven't tried it with newer code, but the major difference I believe was Kevin Watson's updated PWM routine. (Sorry, I don't have the code in front of me to quote chapter and verse.) It's been a month since I stuck my toe into the wonderful world of interrupts, but now I want to dive in and get it done. I'm going to throw some programmers at this and see how far we get this time.
  #47   Spotlight this post!
Unread 16-01-2008, 14:12
Jungle_Ed Jungle_Ed is offline
FRC #0405
Jungle_Ed is an unknown quantity at this point
Hey I just got assigned to a 2008 FRC team. I am going to try using Mike 0.3 code then Qbranch's Code. Anyone, please let me know of you get some ok readings for the Sonar on and FRC robot, and I will be sure to do the same.
  #48   Spotlight this post!
Unread 16-01-2008, 14:32
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
We got the Vex sonar working last night using Mike's driver. I'm really impressed by the whole thing -- it can see a 3' x 4' board at about 15 feet!
Note: the documentation that came with the Sonar sensor I got (from Radio Shack, back when they sold Vex stuff) had the "input" and "output" functions backwards. See my earlier post in this thread.
The wire marked "input" is an input to the sonar, and it needs to come from a rc_digital_io_NN pin configured as an output. You need to set a couple of macros in sonar.h to tell it which pin you are using for the sonar input.
The output needs to go to a digital_io pin that acts as an interrupt. We used rc_digital_io_01. I think that is the default in Mike's code.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
  #49   Spotlight this post!
Unread 16-01-2008, 14:46
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Beware of off-axis error! Depending on what sensor you're using (Parallax PING))) is pretty much your best bet) the further a wall is off axis the worse your measurements will be.
For example, if you were, say, following along a wall and servoing off of the distance from the wall (no idea why you'd want to do that ) you're robot will swerve further and further until it crashes, because, each time the robot veers left or right it alters the distance the ping sensor percieves, even though the distance has barely changed. This escalates until, like I said, you crash.
Instead (and we've used this in the past) use encoders to drive your robot straigh, and use ultrasonics for obstacle detection/avoidance.
Getting a reliable distance to anything at any angle is our current goal at 1024.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
  #50   Spotlight this post!
Unread 31-01-2008, 09:27
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
I have a quick question Mike Dubreuil. YOu ping the sonar with Ping_Sonar and turn the timer on. Then once it interrupts it goed into Hardware_Interrupt_Sonar an into the switch statement for SONAR_WAIT status and you turn the timer on again. Then it goes into the switch statement for SONAR_TIMING for the next interrupt and get phase width as a measurement. Is the phase_width the time it takes for the actuall sound wave to go through the sonar, not the echo from the wall? If it is the echo value, then why start the timer in SONAR_WAIT?
Thanks Stephen
  #51   Spotlight this post!
Unread 02-02-2008, 13:29
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
I have the code setup as gnornhurst posted in the "SONAR Sensor Software Driver" and i'm using rc_dig_out16 for input and digital IO port 1 for "output", but I'm getting a "Cannot find Sonar" error.
I was wondering if there were any additional code changes you needed to make to get this to work with this year's Kevin Watson code?
Thanks.
  #52   Spotlight this post!
Unread 12-02-2008, 14:07
GregK GregK is offline
FRC #0381
GregK is an unknown quantity at this point
Last nite, I set to work adding a second sonar. Because of the limited time, I just made a second copy of Mike's sonar.c and sonar.h (which we are using for the first sonar). I named the second copy sonar2.c & h and changed the global variable names. While checking around to find what else I should change (which interupts and pins I should use), I found out that Mike has written another sonar named jvex_sonar.c routine that handles four sonars (at http://www.koders.com/c/fid735E99BB5...A82C4454.aspx).
What the story with that routine? Would I be better off starting with that code or continue with my approach?
  #53   Spotlight this post!
Unread 13-02-2008, 08:49
dadamson's Avatar
dadamson dadamson is offline
FRC #2546
dadamson is an unknown quantity at this point
After a fair bit of wrestling yesterday, we got the 0.3 Sonar driver talking to Kevin W's 3.0 code. We ripped out references to his pwm.h, mostly (except for #includes) in ifi_frc.c Both it and the sonar driver want to use timer 3.
  #54   Spotlight this post!
Unread 15-02-2008, 23:03
B_Dubbs B_Dubbs is offline
AKA: Brian
FRC #1153
B_Dubbs is an unknown quantity at this point
We, about 2 hours ago, have gotten all of our sonars to work with Kevin's encoder code. We did this by using both Mike's and Kevin's code together. Once we get everything perfectly straightened out, we could post it.
  #55   Spotlight this post!
Unread 06-03-2008, 19:26
mandrews281 mandrews281 is offline
FRC #0281
mandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to beholdmandrews281 is a splendid one to behold
I'm trying the same thing with the Vex sensor and haven't had much luck. I ripped out ALL the pwm references and if I interpret the code correctly (a big if), it's using interrupt2, so I've connected the sensor to dig_in_02. Depending on which output/input I connect to dig_out_16/in_02, I get software malfunction or reversed I get an occasional "device not detected" (usually when I press or release the trigger). Anyway, in all cases the pulse_width (and therefore the distance) is 0.
Any chance of getting more details what you did so I can see what am I doing wrong? Thanks
  #56   Spotlight this post!
Unread 08-03-2008, 11:03
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
Any ideas on how to make an ultrasonic sensor work with Kevin's new 2008 code? I know it handles interrupts differently, and I really don't have a great understanding on how to use interrupts. We're using a Vex UltraSonic Sensor (and it looks like it's digital).
Toshiba Cardbus Problem? jpsaul7usa Chit-Chat 12 01-01-2006 02:37
Introducing the Driver Strategy Database's Online Database impulse3D Rules/Strategy 17 17-03-2005 03:04
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Middle School Drivers ram General Forum 40 26-02-2003 17:01
