#361
Re: New C18 3.0+ Compatible FRC Code
Hi Kevin,
Our robot this year is using four different omnis that need 4 different encoders. The problem is we need to use four encoders this year. We used the encoders 3-6. We noticed that 3-4 were working but 5-6 only gave 0's and 1's. After looking at the ISR's for the encoders 5 and 6 i realized that 3 and 4 only worked on rising edge interrupt but 5 and 6 worked on both. After i changed 5 and 6 to be like 3 and 4 they worked but i do not understand why. there are four variables that i am using, two of which you use that are not declared anywhere. They are Encoder_3_State, Encoder_4_State, Encoder_5_State, and Encoder_6_State. Do you know where these variables are declared. Also why are the encoder 3-4 ISR's different from the encoder 5-6 ISR's. Thanks in advance, Julian |
#362
Encoder channels one and two are optimized for velocity control and will generate the least number of interrupts per encoder count (one per encoder count). These channels may have problems in position control applications because they can be fooled into thinking that the encoder shaft is rotating if the shaft happens to stop very near a phase-A transition and then wobbles back and forth across that transition. Encoder channels three and four are optimized for position control. For these channels, software examines both transitions of phase-A and can't be fooled into miscounting the number of encoder counts. The downside to using these channels is that for a given encoder, they will generate twice the number of interrupts as channels one and two (two per encoder count). Encoder channels five and six are just like channels three and four, but offer the bonus of increasing the precision of your encoder by a factor of two for free. Unlike channels one through four, which will increment or decrement on each rising (zero to one) transition, these two channels will increment or decrement on both transitions of phase-A. In other words, if you attach a 64 count-per-revolution encoder to one of these two channels, you'll read 128 counts when you rotate the shaft exactly one revolution. |
#363
Have you resolved this issue? We're having the same problem, but with the C18 V3.10 compiler & beta code.
First, I really like the new code organization (that seems to be a common theme). One suggestion though. I'd like to see the *_Init routines called whenever the mode switches. This probably won't affect the matches where things are always: disable->autonomous->teleop->disable. But we were chasing a bug in our autonomous because we were forgetting to reset the robot between runs, and the Autonomous_Init() routine wasn't getting called (we were continuously toggling between disabled and autonomous.
Anyway, back to autonomous programming. |
#365
Just FYI, I've updated the code to address these three minor issues:
http://www.chiefdelphi.com/forums/sh...&postcount=348 http://www.chiefdelphi.com/forums/sh...&postcount=351 http://www.chiefdelphi.com/forums/sh...&postcount=360 -Kevin |
#366
-Kevin Last edited by Kevin Watson : 11-02-2008 at 03:33. |
#367
Ann |
#368
I never did solve my problem, though, so there might be a problem lurking in that code. |
#369
We were grabbing some switch values in teleop_init into a static variable to detect when/if the operator changes those switches during the normal teleop(). We do this to avoid moving some of our appendages on first power up until someone at the control panel asks them to move (safety considerations). Since telop_init() was only invoked once, before the first (real) getdata, we didn't see the real OI switches and concluded that the operator had, in fact, moved them when teleop got called after the getdata invocation. Thanks for considering the changes, and check out my next post. It's going to point out another 26.2msec issue in this same area of the code. Lynn (D) - Team Voltage 386 Software |
#371
Kevin,
Given the structure of the code in main() surrounding the modal invocations and the position of the getdata() calls, it appears to me that the new code structure actually invokes the previous mode with the new mode's getdata() results immediately after a mode switch. Consider: robot is in disable, rcdata has that fact recorded, hybrid begins. main() detects disabled mode, detects that new data is available, calls getdata() receiving the new autonomous flag but invokes disabled() anway. Autonomous_init() and Autonomous() doesn't get called until the NEXT command packet, 26.2msec later. I've not done it yet, but I'm planning to restructure our main() to something like this (just pseudo code, not real code): main loop: if (new data available) { getdata(); set newdata flag; } if (...mode...) { all of the existing mode_init and mode() calls here, but no getdata or putdata() calls } if (newdata flag) { putdata(); } goto main loop: With this structure, the newly gotten mode is the one checked and invoked with the getdata() packet. I hope to first prove this with a mode-checking printf in one (or all) of the _init() routine that check if the mode we're in is reflected in rcdata (hidden by the #defines for the mode flags). I suspect it is not. Lynn (D) - Team Voltage 386 Software PS. This also makes our new always_before(), always_after(), and always_spin MUCH easier to hook in, now that I've written it out! always_before() right after the getdata(), always_after() just before the putdata(), and always_spin, well, always in the loop! Last edited by ldeffenb : 11-02-2008 at 14:04. |
#372
Kevin,
We discovered a side effect of the new code setup that I thought I should point out. I've only read this thread sporadically, so maybe it's already been mentioned - if so apologies for bringing it up again. We had some feedback code that we implemented in the _Spin() functions since we wanted it to execute faster than the 26.2ms rate. The side effect that we found was that if you do something which causes your Autonomous() code (for instance) to take longer than 26.2ms to execute, then Autonomous_Spin() will never execute. The problem this caused for us was that our feedback was obviously not running when this occurred. Anyway, I don't consider this a flaw in the code or anything, merely a behavior that I wanted to make sure others were aware of. We will probably modify ifi_frc.c and remove the "else" blocks around the _Spin() functions, which will ensure that the _Spin() code gets executed at least once per main loop. Maybe it would be worth a note in the comment blocks before each _Spin() function noting that those functions will only be called if there's extra time left over after processing the new command packet. Dave |
#373
Thanks for catching this. IFI's code behaves the way you describe, so I went ahead and removed the three surrounding else statements. I also added support for the MPLAB simulation tool. The code is up on my website now. -Kevin |
#374
Kevin,
What is the procedure for adding additional analog sensors with the gyro code? I changed the number of ADC channels, plugged the (pots, in my case) in to channels 2 and 3, and added the code to read them in the Process_Gyro_Data function. While I've been able to read the values (by converting the number to milivolts, as otherwise I'm not exactly sure what I'm seeing), the gyro has since been going crazy. I wired the gyro to an oscilloscope, and it still works, but the code (after given time to initialize and computing the bias) sees crazy values. Any idea what I'm doing wrong? Is there any readme to using the gyro with other analog values I'm missing? Thanks. |
#375
FUNCTION: Process_Gyro_Data() * * PURPOSE: Manages ADC data and does gyro rate integration * * CALLED FROM: ifi_frc.c/Disabled_Spin(), * ifi_frc.c/Autonomous_Spin(), * ifi_frc.c/Teleop_Spin() * * PARAMETERS: Unsigned char with a value of zero will prevent this * function from calling Reset_ADC_Result_Count() when * ADC data has been processed. If you do use this mode * of operation you must call Reset_ADC_Result_Count() * from your own code. Failure to do this will cause * the gyro to stop functioning. |
| Does the camera code suits to all versions of MPLAB and C18? | razer | Programming | 3 | 04-01-2007 14:50 |
| Trying to follow C18 interrupt context code... | dcbrown | Programming | 5 | 21-12-2006 09:01 |
| Error w/ FRC code | JamesBrown | Programming | 2 | 08-01-2005 16:17 |
| Programming code Fix FRC | Ferazel2001 | Programming | 6 | 08-02-2004 02:46 |
| FRC default code | hedgehogger | Programming | 2 | 21-01-2004 18:41 |
