Go to Post Remember. There is no controls team, no mechanical team, and no business team without The Team. - Tom Line [more]
Unread 12-02-2008, 13:43
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Shooters vs Arms
Eric, I guess you haven't seen how easy it is to self load a launcher with just a simple moving arm sticking out the front of it?
Unread 12-02-2008, 13:48
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Shooters vs Arms
Inform me if I am wrong, but by definition, HURDLING is defined in the rules as the trackball ball top being positioned just above the top rail of the overpass, or higher. Therefore, unless shooters shoot from that level (minimum height), they are not considered in the act of hurdling, even though that may be the end result of their shooting the trackball. Therefore, it would seem, blocking the shot is well within acceptable defense. At least, that's my interpretation of what I have read.
Unread 12-02-2008, 13:58
I realize that (I've seen 118's video), but it might be more efficient if the launcher didn't move and had two arm robots supporting it--similar to 2006's "Atom Bomb" strategy. Twice the rate of fire sound good to you?
Unread 12-02-2008, 14:02
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
It's always true how you execute your design is the deciding factor as to how successful it will be. However 118 showed how easy it is to make a great launcher. We contemplated copying that when we saw it. It would have been easy to do (the launcher anyway). I'll bet a number of teams did. Why not?
However, all things being equal, this simply is the most efficient solution, mainly because of the clothesline factor. When executed properly you can't score faster with a mechanism that goes above the overpass for a period of time during the score. So how you get the ball off the ground becomes important, but no reason a shooter can't use the same mechanism an arm can.
Yes there will be plenty of arms scoring faster than shooters, but that will be because of execution or techniques. But if done right I can't see how even the best arm (anything that goes above the overpass) could score faster than the best shooter.
www.179swampthing.org
Unread 12-02-2008, 14:04
MrForbes's Avatar
AKA: Jim
Yes, but the shooters can probably zip around the track and fetch balls at about the same speed as the arm bots. Also some of the shooters (specifically pneumatic ones) probably need the time it takes to make a lap to recharge the air tanks.
Should be fun to see what interesting ways different alliances can come up with to play the game!
Unread 12-02-2008, 14:07
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Personally the best robots this year will be a combination of both, we will see robots that can knock down, pickup, place, and shoot the ball. I am willing to bet that a couple of the top teams will build a bot that can do all of the above extremely effectively, hey we haven't seen 71, 111, 67, 254, 233, 1114 ect. yet!
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 12-02-2008, 14:27
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I'm totally with EricH, i would like to see 2 arm robots and a shooter alliance
R.C.
MadTown Robotics Team 1323
Unread 12-02-2008, 14:40
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Team 836 has designed our bot to do just that. All the various components work quite well, and tonight we will start the extensive integration testing to see how effectively they all will work together.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 12-02-2008, 14:52
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
I think a third classification should be added to this thread...
Throwers.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 12-02-2008, 15:04
cwood's Avatar
cwood cwood is offline
AKA: Chris Wood
FRC #1629 (Garrett Coalition)
cwood will become famous soon enough
just for discussion purposes hat if said shooter were capable of knocking a rather large mentor off his feet from the opposite side of the field, what would be your plan to easily block it. without getting you robot destroyed
what do you mean its too expensive?
-visit http://www.team1629.com
Anyone play tribalwars message me on w11 name is wooc3860
Unread 12-02-2008, 15:09
Brandon Holley's Avatar
Blocking a ball is a completely legit strategy.....but you better bet the team blocking is taking a risk by attempting to "stuff" you. Doesn't mean they can't do it though.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 12-02-2008, 15:11
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Originally Posted by The Manual, Game Section
HURDLING: The act of completing a HURDLE. To be considered in the process of HURDLING,
the ROBOT must:
 be in its own HOME STRETCH, and
 be in POSSESSION of a TRACKBALL, and
 be moving toward the OVERPASS and/or elevating the TRACKBALL so that the top of the
TRACKBALL is higher than the LANE DIVIDER.
So a robot that is in its home stretch, in possession of the trackball, and moving toward the overpass, it is in the act of hurdling and therefore still protected from contact to it or its trackball.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 12-02-2008, 15:16
cwood's Avatar
AKA: Chris Wood
well they could probaly do it once and the ball could leave the robot from above 5 feet so i believe that what ever is used to block the ball will end up dangling from the robot so i believe it will happen once until teams see the results
Unread 12-02-2008, 15:37
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Well,
1. Shooters can have mechanisms to knock the ball down. I know my team does and,
2. A hurdle at the end of the game rather than setting it back on the overpass is just as good, you just miss out on a couple points.
I think effective shooters will dominate this years game.
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
Unread 12-02-2008, 16:21
cwood's Avatar
AKA: Chris Wood
Thank you hill i believe that will be the case as well
Horizontal Shooters Sachiel7 Technical Discussion 10 24-02-2006 08:12
2 Shooters??? Jon Jack Robot Showcase 14 26-01-2006 20:00
Shooters or Nonshooters Kevin_547 Rules/Strategy 6 21-01-2006 22:28
Female Shooters JulieB Championship Event 29 28-04-2004 16:47
Pure Shooters Andrew Rudolph General Forum 5 04-03-2002 20:53
