Go to Post Remember the volunteering is not mandatory for the people to do it. It IS mandatory if FIRST is to survive and the regionals to leave a positive impact on everybody. - Alavinus [more]
Unread 11-02-2008, 18:49
Drakan290 Drakan290 is offline
FRC #0116
Drakan290 is a splendid one to beholdDrakan290 is a splendid one to beholdDrakan290 is a splendid one to beholdDrakan290 is a splendid one to beholdDrakan290 is a splendid one to beholdDrakan290 is a splendid one to behold
Merging two assembly files?
I made a few changes to an assembly, and so did some other members of the team. Now, I want to integrate their changes into mine, and visa versa... Is there any way to do that without redoing all the changes either I did or they did, to each others' file?
Unread 11-02-2008, 19:08
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Merging two assembly files?
Did both of you make changes to the same file?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 11-02-2008, 19:30
FRC #0116
Yes.. Same file, now they are different versions.
I cut lightning holes in the gearboxes, and a few other things, like constraining the risers.. They added bumpers and put the hardware boxes on there.. It'll save a good hour of work if we can combine the two files.
Unread 12-02-2008, 15:27
Molten's Avatar
AKA: Jason
Ok, I would just take the bumpers he added and put them in your file. Then go ahead and constrain them (It should only take 10 minutes at most if you use the tools efficiently.) Then, I would do the same thing with the hardware boxes. It shouldn't take anywhere near an hour to do this unless he has like 10 boxes all of which would be in unusual constraints. A short cut might be to put both of your assemblies into a new assembly and then deleting the stuff from his that you changed and vice versa. Then simply constrain the frames to overlap. This is an extremely cheap way of doing it and I advise that you use my first idea. However, it will get the job done even if it does break the laws of physics.
Did I help? If so, please let me know which one you chose and how it worked. If you come across errors, let me know and I will try and help you resolve them.
Merging files fireball3004 3D Animation and Competition 3 30-09-2007 12:18
Converting step files to inventor files GMAdan Inventor 4 01-01-2007 20:09
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
Putting two and two together... Andy Grady General Forum 13 08-01-2004 18:29
