Go to Post Finish... what an interesting concept. I'm still hoping to do that to our 2003 bot. - Joshua May [more]
Unread 12-02-2008, 00:09
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Wire Discussion
On FIRST robots you are allowed to use different gauge wires for different motors depending on the amperage of the breaker protecting your circuit [speed controller, relay, RC, custom circuit, etc.].
What type of wire do you use (what gauge)? Do you stay consistent throughout your robot (Ex: X AWG wire for all motors, Y AWG wire for all sensors)? Have you ever calculated the power lost with lower gauge wires? Is there a reason for the gauge of wire you select? Have you ever tried to cut back on the weight of your robot by reducing the gauge of some wires? Has your team ever used a different gauge wire in the past and if so, why did they change?
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 12-02-2008, 12:13
Re: Wire Discussion
The price of copper drove my decision this year, and went with 12 awg. Prices more then doubled since I last bought it in 2006. Before that, we used 10 awg instead of 12 awg.
Unread 12-02-2008, 14:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Wire Discussion
Wire prices sure have gone absolutely through the roof. We use 4ga ultra-finely stranded audio power wire for our main power runs from the battery and to the Rockwell block and breaker panels. We paid $6 per foot for it locally. It is available for about $3.50 per foot online. The 4 gauge is useful for the main power runs. With the kind of current FRC robots can draw, you can get a considerable voltage drop over 6ga (especially the low strand count wire they give you in the KOP).
We traditionally position CIM motors so we don't have to extend their wires. For power to the Victor speed controls we use regular 12 gauge power wire. On 500 series can motors we use 14 gauge zip cord and for spikes we use 18 gauge zip cord from McMaster.
On a related note, does anyone know why a good red (red, not pink) color wire is so hard to come by. Seems like more manufacturers are making it an off-red color that is closer to pink.
Unread 12-02-2008, 15:35
Re: Wire Discussion
Sanddrag,
I have noticed that the newer red color shows a distinct color change with temperature. (soldering) That may have been a design choice.
Unread 13-02-2008, 07:35
Re: Wire Discussion
Answering the original question...It depends.
I prefer to use #10 for all drive motor wiring. In general, we will mount the controllers for the drives near enough to the motors to use the supplied motor wiring directly to speed controller. We use #10 for any motor with higher current, Chalupa large and small, Fisher Price, etc. #18 power wiring for all Spikes not feeding motors, and larger if feeding a motor.
We will submit to using the minimum guage when weight is an issue, i.e. at the end of the arm last year or when the robot is really overweight and the lower guage won't affect performance. Sensors use #24 or #22 depending on where they are located and what they are used for. Wheel speed sensors that we have used in the past for crab drive, might get a #22 to connect to the drive module and then transition to a #24. Pots and switches get #24, since we use PWM bulk cable for wiring those devices. And of course, short pieces of #6 to connect the fuse panels, main breaker, battery and the Rockwell block.
Unread 13-02-2008, 09:38
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: Wire Discussion
I am surprised you go to a larger main wire but for your drive victors you still only use the minimum. You could still get a good voltage drop on 12 if your motors are pushed.
-Mike
Unread 14-02-2008, 04:48
Re: Wire Discussion
-Mike
We use 12 for its tighter bend radius and smaller size which allows us to route it more cleanly. Additionally, our power runs to the victors are quite minimal, some as little as 3 inches.
Extra Discussion for Picture Discussion Ianworld Robot Showcase 1 31-01-2005 01:28
Repeated discussion archiver 2000 0 23-06-2002 23:56
