Go to Post A winning robot is not a winning robot unless you have winning drivers too. You need the time to develop both. - Jim Zondag [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 12-02-2008, 16:53
Re: Battery?
Originally Posted by Tiix View Post
If you include batteries, you must:
 Ship them inside their original box or carton packaging.
 Use the Styrofoam covering with protective caps to cover the battery terminals.
 Secure the boxed batteries inside the “inner battery box” section of the robot crate in an
upright position. The photograph below shows a sample of an inner battery box built to
comply with regulations. Remember to label this box…see below.
That is The directions in 4.2 of the manual... The first Bullet (or box as it showed up there) says ""Ship them inside their original box or carton packaging."" No clue if I'm making sense yet... fifteen things going on right now!!!!!!
OK, now I understand. I would say you can't just do the box for the crate; sorry, that's the rules. You'll need to follow the Q&A's direction on the cardboard box. Or, just bring the batteries with you (if you're driving to your event--flying with the batteries is not recommended).
Battery Pneumaticsman Technical Discussion 9 18-01-2008 10:56
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Battery archiver 2001 4 24-06-2002 01:10
battery archiver 2000 1 24-06-2002 00:26
battery archiver 2001 0 23-06-2002 22:51
