Go to Post You can't unwind after build season knowing that competition season is just around the corner! ;) - Hallry [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 04-02-2008, 10:29
team550 team550 is offline
FRC #0550
team550 is an unknown quantity at this point
TOUGH BOXES
are your toughboxes loud ?
our toughboxes are rather loud compared to other years bot gearboxes.
Unread 04-02-2008, 10:38
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: TOUGH BOXES
did you guys add grease to the gears. we can hear a little grinding noise but i think thats just normal from the gears meshing but it shouldnt be that loud.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 04-02-2008, 10:40
FRC #0550
Re: TOUGH BOXES
we did add grease and it is still loud
Unread 04-02-2008, 10:43
seanl's Avatar
Re: TOUGH BOXES
how loud on a scale of 1-10?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 04-02-2008, 10:45
FRC #0550
Re: TOUGH BOXES
like a 7 or 8 compared to last 3 years
Team 550 Team account
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: TOUGH BOXES
Even with grease, our Toughboxes sounded pretty loud when we first ran them. We've spent a lot of time letting our drivers run laps, though, and they seem to have quieted down as they wore in.
Jeff Waegelin
Unread 04-02-2008, 10:49
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: TOUGH BOXES
Remember that clear lexan plate basically turns the gearbox into a speaker box and amplifies all sound, compared to the (almost completely enclosed) cast metal boxes of years gone by.
Replacing that plate with a metal one proves that statement, and solves other problems you may discover down the road as well which are far more important than how loud it is.
seanl's Avatar
Re: TOUGH BOXES
i agree they get way better when you wear them in.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 04-02-2008, 10:53
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: TOUGH BOXES
To add to what Jeff said...
I think the Toughboxes are louder than the 2005/2006 KOP transmissions because of a few design differences.
First, I think the Lexan side plate "resonates" a bit and just makes it sound louder even if the internal conditions are the same as the old boxes.
Second, the internal conditions are different from the 2005/2006 KOP boxes. The older ones used thicker gears and had spacers to locate the gears on the shafts. The Toughbox has a thinner gear face, and the spring pin that locates the gear on the shaft allows it to "flop" around a bit which adds more of a ringing sound.
Do not trivialize grinding sounds however...I would open the box, look for burrs or misalignment anywhere, grease it with lithium grease and reassemble.
A good way to break in your boxes is to run them off of a bench top power supply that shows current draw. Look at the free current of your motors and if the setup you have draws significantly more that you expect, then you should break down and rebuild the transmission.
The lithium grease is also thick and can help dampen sound. We greased our gearboxes and ran them on the bench for about 20 minutes each to break them in. They sounded alot better after the break in period, but are still louder than the 2005/2006 KOP transmission or the AM 1 speeds we used last year.
Remember, it is really worth taking your time to get it right here...your drivetrain will be the most critical system on your machine!
Good Luck,
RAZ
Unread 04-02-2008, 10:58
Brandon Holley's Avatar
Re: TOUGH BOXES
As others have said,
do not trivialize a grinding sound in a gearbox. check it out, look for visual signs of wear and tear (aka metal filings/ burrs on gear teeth). If you do see stuff like this, break that transmission down, clean it out and rebuild and retest, if it continues to happen, you may have much bigger problems than loud trannys.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 12-02-2008, 17:01
Tiix's Avatar
Tiix Tiix is offline
THE Girl on the Team
AKA: Tori
FRC #2511
Team Role: Student
Tiix is an unknown quantity at this point
Re: TOUGH BOXES
They are Loud... But are A lot better once you grease 'er up it... atleast for us!
If it Can't Make you Laugh, SCREW IT!!
Unread 05-03-2008, 15:33
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
Re: TOUGH BOXES
i know this post is about toughboxes, but does anyone know why the anymark supershifters are loud enough to hear accrost a parking lot?
they're lowder in high gear, and we greased them alot, and checked that all the gears and bearing were installed properly, and not grinding,
any ideas,
our bot works fine, and drives 4311ishly fast :-)
[center]
Unread 05-03-2008, 15:44
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: TOUGH BOXES
As others have said, make sure you check ALL the bearings. We got an AndyMark supershifter (uses some of the same bearings as the kit boxes). It was dragging and hard to turn - imagine our surprise when we found a totally bound up bearing inside it. Luckily we were able to replace the bearing with one from the kit transmissions and we're driving again.
It was very curious when the bot kept wanting to turn right
Unread 05-03-2008, 15:45
AdamHeard's Avatar
Lead Mentor
Re: TOUGH BOXES
One issue I think people have is there basis for loud.
Fact is, spur gears make noise. Lots of spur gears make lots of noise.
Break them in and use grease liberally, but you will never get them to be quiet. A lot of people are used to their previous robot in competition (where the stadium drowns out any gearbox noise) and are shocked to hear their new robot.
Future of Education: Tough Choices or Tough Times Rich Kressly Math and Science 0 21-12-2006 09:10
pic: Tough cookkie frame Tytus Gerrish Extra Discussion 15 31-07-2006 12:48
pic: One Tough Train Rod Extra Discussion 33 11-04-2005 21:33
A Reminder When Things Get Tough.... Joe Matt General Forum 4 05-01-2005 13:36
