Go to Post What is this? PVC pirates with no visible PVC? (at least that I can see) IMPOSTORS! - theawesome1730 [more]
Unread 12-02-2008, 17:35
captainking's Avatar
captainking captainking is offline
Level 85 Programmer
FRC #0168 (MIB)
captainking is an unknown quantity at this point
pwm controlled by relay
in our code we want to be able to control pwms through buttons on the controller, but the only place we can find button commands are on relay blocks, and IF statements haven't worked for us so far, any ideas? Thanks in advance.
Unread 12-02-2008, 17:41
blaxbb blaxbb is offline
Ohio State Engineering Scholar
AKA: Brian Barrett
FRC #2331
blaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really niceblaxbb is just really nice
Re: pwm controlled by relay
You can use relays to control motors, but you wont have the speed control that using a PWM value would give you.
When you program it assign a button to forward and reverse
relay1_fwd = p1_sw_aux1;
relay1_rev = p1_sw_aux2;
"Whether you think you can or think you can’t, you’re right." - Henry Ford
www.vthsrobotics.org
Unread 12-02-2008, 17:56
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
We have done exactly this in the past.
if (p1_sw_top && !p1_sw_trig)
pwm04 = 225;
else if (!p1_sw_top && p1_sw_trig)
pwm04 = 50;
else
pwm04 = 127;
Unread 12-02-2008, 18:03
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
We have to do the same thing, but we have to have the motor turn one direction all the time and the other only when the button is pressed.
if(p2_sw_aux1 == 1)
		relay1_fwd = 1;
		relay1_rev = 0;
else
		relay1_fwd = 0;
		relay1_rev = 1;
Unread 12-02-2008, 18:38
Level 85 Programmer
FRC #0168 (MIB)
I think I should be a little more specific, we want to be able to switch from one set up to another by the push of a button, but we can't find a way to switch pwms through that. All of our if statements haven't worked, is there a way to assign for example, tank drive to trigger and arcade mode to aux?
Unread 12-02-2008, 21:27
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
You could use static variables to achieve these means.
static unsigned char Tank_Drive = 1; //default is tank drive
if (p1_sw_trig) Tank_Drive = 1; // enable tank drive
else if (p1_sw_aux1) Tank_Drive = 0; // enable other drive system
if(Tank_Drive)
     // code for tank drive here
else
     // code for other drive system here
What this will do is switch to tank drive when you press the trigger and switch to another drive system when you press the aux button. Not when you hold them down, but when you press them.
Unread 13-02-2008, 01:29
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
Yep. That is exactly what we do to produce an "on/off" button effect. It has to be modified slightly to use 1 button for "toggle" instead of 2 distinct "tank" and "other" buttons. I don't know why you want to drag a relay into this, and I am almost sure I don't understand what you are asking. Could you explain better?
What about buttons on the joysitck? Digital inputs on the OI? (Or even resistors in parallel?)
Silicon Controlled Rectifier teh_pwnerer795 Electrical 37 26-11-2007 07:09
Guage of PWM/Relay Cables Jake M Electrical 2 07-02-2007 00:49
PC Controlled Robot EHaskins Programming 6 05-11-2006 06:45
Servos controlled by RC? Obi Programming 5 01-02-2005 14:43
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
