Re: Inventor
This has been asked so many times on here. Use the search tool and I am sure you will find a way. I don't really know myself, because I have found it to be too tedious to be worth it.
FYI: When it has been discussed in the past it involved a long complicated method. If you are not a true expert at CAD, I would not suggest you try it. Seeing as you are probably going to try it anyways, Good Luck.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
