Go to Post You shouldn't have to apologize at all for wanting to have fun. This is supposed to be fun. You shouldn't gauge your level of enjoyment at the event based on your place in the standings. - Koko Ed [more]
Unread 12-02-2008, 19:54
skrew-ball skrew-ball is offline
None #0975
skrew-ball will become famous soon enough
IR Board Modifications?
My team was planning to modify the IR board that we recieved. We want to potentially put an IR sensor from an XBOX reciever on the board, since it's a proprietary IR signal and would interfere much less than a traditional remote control. I couldn't find anything in the rules or the checklist explicitly prohibiting the modification of the board, does anybody know any differently? Does anybody think that this would be a prudent modification?
Unread 12-02-2008, 20:07
Re: IR Board Modifications?
According to the GDC Q&A, you may modify the IR sensor board without violating the rules.
I don't understand what you intend to replace, however. The part of the board that decodes and recognizes the IR command is the software.
Unread 12-02-2008, 20:49
taggartbg taggartbg is offline
FRC #1712 (Dawgma)
Team Role: Electrical
taggartbg will become famous soon enoughtaggartbg will become famous soon enough
Send a message via AIM to taggartbg Send a message via MSN to taggartbg Send a message via Yahoo to taggartbg
You're allowed to, but again, there's no real reason to. You can use an xbox remote with this IR board just fine with what you have. The IR photocell in the xbox receiver isn't going to be any different from that on the IR board you got from FIRST.
Wheelchair modifications Wheels Technical Discussion 10 12-01-2007 20:06
Modifications archiver 2000 4 24-06-2002 00:13
Wheel Modifications? archiver 2000 1 24-06-2002 00:13
Segway Modifications...... Clark Gilbert Dean Kamen's Inventions 11 06-12-2001 21:59
Drill Modifications Mike McIntyre OCCRA 0 16-10-2001 06:09
