Go to Post Just like it is not all about the robots, it is not all about winning the Chairman's Award. - Paul Copioli [more]
Unread 12-02-2008, 19:49
Spiders Spiders is offline
Rookie Team
FRC #2599 (Full Throttle)
Spiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to all
Send a message via MSN to Spiders Send a message via Yahoo to Spiders
Pneumatic Problems
So we have all the pnuematics set up correctly running 60 on the regulater and 115 (?) on the pressure switch before it stops, but the pneumatic wont extend, the double solenoid is connected to the spikes with fwd and rev on each but is not working?? not even the manual buttons work! whats wrong?
Unread 12-02-2008, 20:01
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Pneumatic Problems
did you wire the solenoid by putting the
2 black together which goes into the breaker panel
wiring the 2 red wires with diodes going to the relay?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 12-02-2008, 20:07
Rookie Team
...? um no lemme try
Unread 12-02-2008, 20:10
Rookie Team
so the black go to the 20 amp breaker and the red each have there own spike?
Unread 12-02-2008, 20:12
seanl's Avatar
2 blacks go to ground on the breaker panel. and the 2 reds go to the spike with a diode to the m+ and m- on the spike.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 12-02-2008, 20:14
Rookie Team
we dont have any diodes, do we have to have them?
Unread 12-02-2008, 20:17
seanl's Avatar
im not sure on this but... i think you can have the black and red going to 2 different spikes or.. if you have any extra led u can use those(light emitting DIODE )
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 12-02-2008, 20:21
Rookie Team
its like this atm
Unread 12-02-2008, 20:22
Rookie Team
nvm it corrupted
Unread 12-02-2008, 20:26
seanl's Avatar
i cant really tell anything from that pic
, Sean
TEAM 867
-electrical
-pneumatics
-programming
Unread 12-02-2008, 20:27
Rookie Team
is the magnetic switch have to be on there also?
Unread 12-02-2008, 20:30
Rookie Team
here is another, the red are coming from the dble soliniod
Unread 12-02-2008, 20:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Diodes have not been required on Spikes for several years. You should have the two blacks running to the ground on your circuit breaker, a red to M+, and a red to M-. Of bigger concern here, though, is that your solenoids aren't even switching manually... hopefully someone with more pneumatics expertise than I can offer some insight.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 12-02-2008, 20:34
Rookie Team
so the two reds are goin to one spike then?
Unread 12-02-2008, 20:37
Rookie Team
dang we are really confused on these lol
Pneumatic device wrenauld Pneumatics 3 24-01-2007 10:28
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
problems with pneumatic tubing in telescoping arm johnnymac4545 Pneumatics 5 25-02-2005 11:19
Pneumatic Confusion Cyberguy34000 Pneumatics 10 13-01-2005 02:01
Pneumatic Cylinders MASherry Pneumatics 1 09-01-2005 18:49
