Go to Post I guess I should read the manual. - r_towle [more]
Unread 12-02-2008, 20:23
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Shooters vs Arms
Originally Posted by hill View Post
Being able to set the ball up on the overpass gives you 12 points while doing another hurdle and crossing the line gets you 10. Where is the major advantage in 2 more points?
Well, four more points, because you could also drive under after you place the ball. (or push the ball under, drive under, and put it up for 6 more points!)
But I think the real advantage to the placing the ball at the end is that you can do it on either overpass (correct me if I'm wrong...). So if you are stuck on the wrong side of the field and need a quick 12 points to win the match, placing the ball up is the way to go.
Horizontal Shooters Sachiel7 Technical Discussion 10 24-02-2006 08:12
2 Shooters??? Jon Jack Robot Showcase 14 26-01-2006 20:00
Shooters or Nonshooters Kevin_547 Rules/Strategy 6 21-01-2006 22:28
Female Shooters JulieB Championship Event 29 28-04-2004 16:47
Pure Shooters Andrew Rudolph General Forum 5 04-03-2002 20:53
