Go to Post Nobody wins a Regional on Thursday. - Bill Moore [more]
Unread 08-02-2008, 13:02
jagman2882 jagman2882 is offline
former driver, now mentor
AKA: Cory Gramlich
FRC #1126 (SparX)
jagman2882 has a spectacular aura aboutjagman2882 has a spectacular aura aboutjagman2882 has a spectacular aura about
Send a message via AIM to jagman2882
Re: Mounting an arm potentiometer
Originally Posted by Alex Cormier View Post
1126 has used the pneumatic tubing with a little heat to attach it to the pot, haven't had any issues with it.
no we actually use tiagon tubing (not sure if that is spelled right)
2003-2008 Match record 132-59-1
'04 Newton Division Champ, '06 Galileo Division Champ
'03, '04, '08 Buckeye Champs, '07 Finalist
'06 Finger Lakes Champs, '08 Finalists
'08 Buckeye Motorola Quality Award
'07 Buckeye General Motors Industrial Design Award
'05 Buckeye Radioshack Inovation in Control award, '06, '07 Finger Lakes Rockwell Automation Innovation in Control Award
Unread 08-02-2008, 13:32
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
In '05, '07, and this year, we've tapped off the first arm reduction sprocket (as seen here - that picture is from '07). Generally we mount an idler sprocket to help tension the chain, then tap the pot sprocket off of the idler. Keeps things simple. Couldn't find any other pictures, but you can try scanning through Joe's website for any that I may have missed.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 12-02-2008, 21:48
Hazmatt's Avatar
Hazmatt Hazmatt is offline
AKA: Matt
FRC #2645 (PowerSurge)
Hazmatt will become famous soon enoughHazmatt will become famous soon enough
It was a pain, but i finally got it mounted with a belt drive. Can someone clarify something for me, though? Do all the pots i use have to be 100k, are other pots against the rules?
Unread 12-02-2008, 21:53
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
We used a 1k pot, driven via K'nex gears! its really cool and works very well.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Human Arm Arm Controller SgtMillhouse648 Control System 5 09-01-2008 00:03
424's 2007 robot arm is very similar to 340's 2004 robot arm. Ross340 Robot Showcase 7 19-11-2007 21:11
Arm mounting on moving tracks? welderman5000 Technical Discussion 4 10-01-2007 00:16
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Mounting the arm Jesse Technical Discussion 11 10-02-2004 23:20
