Go to Post They improvised. They overcame. They persevered. And they succeeded. ... I cannot remember being more proud of a group of students with which I have been associated. - dlavery [more]
Unread 12-02-2008, 21:22
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Question Running Vex servos
I am having trouble running a vex servo using a FRC controller. I assumed that the servos would be able to use a PWM signal and move accordingly. I was wrong. A snippet of the code that I was attempting to use would be the following. Simply I am asking for a bit of code that would fix my problem.
pwm01 = p1_y;
--or--
if (p1_sw_trig == 1){ // Analog input from the Joystick
pwm01 = 255;}
else{
pwm01 = 127;}
( I know that I have unnecessary { }'s )
Anyone have something that would be helpful, any bit of code or wisdom would be greatly appreciated
Unread 12-02-2008, 22:11
Re: Running Vex servos
Can you define the problem? Specifically, what are you expecting to happen, and what is happening instead?
Unread 12-02-2008, 22:25
What is happening is nothing at all, what I would like to happen is the servo moving to a position and halt there. I have tested the servo, it works with VEX items it's just the FRC that I won't cooperate with the robot controler.
Unread 12-02-2008, 22:36
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
is it plugged in correctly? and is your backup battery charged?
Unread 12-02-2008, 22:38
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
I think this is probably your problem, because your code looks fine. Servos are powered exclusively by the backup battery. If this battery is missing or discharged, then you won't see the expected motion.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 13-02-2008, 18:34
Ahh, that would make a lot of sense. I did indeed not have a backup battery that was charged. Thanks a lot to you guys for your help.
Servos? PrincessJae Motors 15 26-01-2008 01:33
Vex Servos John Gutmann Technical Discussion 2 26-02-2007 17:31
Vex servos burkechrs1 Motors 3 08-01-2007 17:59
VEX servos JasonQ FIRST Tech Challenge 2 07-12-2005 15:14
servos savage Technical Discussion 5 09-04-2005 20:52
