Go to Post FIRST already has 494 Martians, plus 70 more. - GaryVoshol [more]
Unread 12-02-2008, 23:32
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Gyro instead of GTS
Hi, Our team is going to try to manage our rate of turn using the gyro. We are concerned that the max turning rate for the gyro is 80deg and that this will limit our turning rate. Has anyone had a problem with the turning rate of the gyro in the 2008 kit? We didnt participate in the 2007 competition, but would it be legal to use the 150deg/s gyro? Does anyone know if the 300deg/sec gyro will work well with Kevin's Code?
Thanks
Windell
#2477
Powering the IR detector from +5V instead of 7+ V. PhilBot Sensors 7 05-02-2008 22:10
Encoder, GTS, Gyro, Camera != Work purduephotog Programming 1 18-02-2007 17:20
omni wheel instead of mecanum wheels Leav Technical Discussion 4 15-01-2006 18:53
SERAL INSTEAD OF DEBUG... EGG0900 Programming 2 05-11-2005 18:25
Instead of Castors .... shyra1353 General Forum 4 20-02-2004 14:29
