Go to Post ....you can't go to a single FIRST event without someone saying "Hey, Look! It's SuperNerd!" - [more]
Unread 13-02-2008, 00:07
Griffin's Avatar
Griffin Griffin is offline
FRC #1983 (Skunkworks)
Griffin will become famous soon enough
Kevin Watson's gyro code isn't compling
We are trying to get our gyro up and running, so we downloaded Kevin's gyro code. If we try to compile it, it gives an error saying that it cannot compile FRC_library. We thought it might be an outdated version of the library, but when we put in a new version of the library in the code, it gave the same error. We really want to get the gyro running and appreciate the help.
Help with Kevin Watson's 2008 code 2526 Programming 6 05-02-2008 16:53
Kevin watson's sensor code DustinB_3 Programming 3 30-01-2008 21:07
Problem compiling Kevin Watson's code Spencer E. Programming 2 07-01-2008 00:34
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
