Go to Post Strategy is rarely static, and how you design your robot isn't always the best way to win the game. - Bill Moore [more]
Unread 13-02-2008, 00:07
Griffin's Avatar
Griffin Griffin is offline
FRC #1983 (Skunkworks)
Griffin will become famous soon enough
Kevin Watson's gyro code isn't compling
We are trying to get our gyro up and running, so we downloaded Kevin's gyro code. If we try to compile it, it gives an error saying that it cannot compile FRC_library. We thought it might be an outdated version of the library, but when we put in a new version of the library in the code, it gave the same error. We really want to get the gyro running and appreciate the help.
Unread 13-02-2008, 00:48
Re: Kevin Watson's gyro code isn't compling
What version of the compiler are you using? It sounds like you might be using 2.4. Make sure to follow all the directions in the readme.txt.
Unread 15-02-2008, 17:25
Ackermani's Avatar
Ackermani Ackermani is offline
Programmer/Minion/Operator
FRC #1983 (SkunkWorks)
Ackermani is an unknown quantity at this point
We are pretty sure the problem you stated is our problem, except the other way. We found that we are using C18 v3.15. We are currently searching for our MPLAB CD to install v2.4, and update to 3.1.
Thank you for your response.
Unread 15-02-2008, 20:34
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Just download the 3.16 update and apply it and you should be good to go.
-Kevin
Kevin Watson
http://kevin.org
Help with Kevin Watson's 2008 code 2526 Programming 6 05-02-2008 16:53
Kevin watson's sensor code DustinB_3 Programming 3 30-01-2008 21:07
Problem compiling Kevin Watson's code Spencer E. Programming 2 07-01-2008 00:34
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
