#31
Re: Shooters vs Arms
I personally feel that a combination of both a shooter and arm are vital to this year's game. Shooters are fast at some things, and absolutely horrible at others etc. placing on top of overpass. Arms are the same way. They both have their pros and cons, and to work to the best of their abilities, must work together to score the maximum number of points. We have an arm this year, but have come up with a way to score more points than the average arm....wait and see.......
#32
Being able to set the ball up on the overpass gives you 12 points while doing another hurdle and crossing the line gets you 10. Where is the major advantage in 2 more points?
#33
But I think the real advantage to the placing the ball at the end is that you can do it on either overpass (correct me if I'm wrong...). So if you are stuck on the wrong side of the field and need a quick 12 points to win the match, placing the ball up is the way to go. |
#34
My team has built a shooter but I think that well-built lifters will provide major competition. A well-built, fast, and coordinated lifter will be just as powerful as a shooter in my opinion. Some teams have already proved this with their videos they have released. Sam N. |
#35
I wouldnt be so quick to state that if i were you (=
in the end, the only major advantage that a shooter has over a lifter is that they dont need to stop in order to score. However, like lifters, they also have a range of scoring positions. For example, for a lifter to score, it will typically need to be right in front of the overpass before releasing the ball so that it can go over. With a shooter, if it is too close the ball will hit the underside of the overpass, and if it is too far away it might not go over altogether. |
#36
Another bot would have an awfully hard time getting in the way to start with, and then the 10lbs + momentum of the ball would be impacting the blocking robot 6ft in the air or so. I smell tipsy robots. |
#37
Also if you were a shooter, wouldn't you have tested the tar outta of it? shouldn't you be able to get yourself in range of the overpass to be able to shoot it and land on the overpass, all it takes is testing and figuring out how far back you would have to be. Just my two pennies Jake |
#38
One thing I've noticed is that many of the successful "arms" are VERY adept at picking up the balls quickly (rollers: 121, 179, 1902...) Yet they are slightly slower when it comes to hurdling. The catapults on the other hand, excel at hurdling, but struggle to pick up the ball. I believe that in the end the two designs will hurdle equally fast. Catapults will hurdle faster, and arms will pick-up faster. (provided of course that both designs are properly executed) This is all the result of engineering trade offs... |
#39
We have an "arm" that picks up the ball just fine and loads it on the launcher.
It turned out that it is much easier than we thought it would be. |
#41
I agree with you, and think that they will provide lots of competition. It is just my opinion that I think "effective" shooters will dominate the game.
#42
IMO those kinds of robots are going to be the winners in the end
#43
Our shooter has a fork on the front ( similar to 1726) and we can get the ball on the run. I have actually found it easier than it was to pick up ringer with our arm last year. Many less capable arms will requier more aiming to pick the ball up just right. I think where the shooters will gain the advantage is precision. Shooters can be a little (for lack of a better word) sloppier can still score. I would even dare to say easier to build and upkeep.
#44
I'll tell you from firsthand experience that even though arms are a good idea, shooters are going to make the points. Our problem that we've had since week 3 (When we started on the arm) is that....well, the arm motors can't lift the combined weight of the arm, the claw, and the ball. So, we tried a lighter arm. Still couldn't lift the combined weight. Given the fact that our team doesn't have much to work with, we changed strategy.
Shooters have their advantages, and so do arms. They both have their cons. Just depends on what you want to do, really. |
#45
Shooters all the way. Yes arms can get the balls on top if need be, but frankly people, the balls can easily be knocked off the overpass almost as easily as they were put up there. It's similar to 2003, it was too easy to remove the big points.
| Horizontal Shooters | Sachiel7 | Technical Discussion | 10 | 24-02-2006 08:12 |
| 2 Shooters??? | Jon Jack | Robot Showcase | 14 | 26-01-2006 20:00 |
| Shooters or Nonshooters | Kevin_547 | Rules/Strategy | 6 | 21-01-2006 22:28 |
| Female Shooters | JulieB | Championship Event | 29 | 28-04-2004 16:47 |
| Pure Shooters | Andrew Rudolph | General Forum | 5 | 04-03-2002 20:53 |
