Go to Post ...there's no easier way to get something changed than to have it happen on FIRST's biggest stage. - Billfred [more]
Unread 13-02-2008, 03:06
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
Re: Importing Teams in FTC Scorekeeper
Just a general question here:
My team ran the NYC FLL event last year. While I was not officially in charge of anything, I ended up having to battle with the scoring software given to us. I don't know if the FRC/FTC software is the same, but for FLL it was this huge, foreboding, complex, excel spreadsheet. This really didn't scale well (as we had 4 tables running at once, and 2 scorekeepers entering data into the machines), and pushed us to using paper for most of the score data transfer...
I was going to try and create a web-based system for next year's fll (local apache server). Can't FIRST create either a server-client based scoring system, or some sort of ad-hoc network? Or were we the only people to dislike the Excel system?
Unread 13-02-2008, 07:38
Shof Shof is offline
AKA: Shaun
Shof is a jewel in the roughShof is a jewel in the roughShof is a jewel in the rough
neutrino15,
the ftc software is totally different and easier to work with since there is no need to play around with any kind of excel system. Also in the ftc software is a server that works in ad-hoc mode meaning you can have one scoring system and another computer in the lan doing the displays
Unread 13-02-2008, 07:50
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
Shaun,
It should be fairly painless. Are there any commas in the names of any teams or schools? That could screw up the import since the software uses commas as the separator between fields. If you want, send me a private message and I'll send you the one I use to import for NJ that you can test with or modify.
If you are working on the file in Excel, make sure that when you save, you tell excel to keep it in the original format.
George
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
[FTC]: 2008 FTC World Championship volunteers needed KathieK FIRST Tech Challenge 0 20-01-2008 21:54
[FTC]: [FTC]: Ontario Provincial FTC Start/End Times cbhl FIRST Tech Challenge 8 16-12-2007 13:37
[FTC]: Ramp Riot FTC Scrimmage Feedback Ben Mitchell FIRST Tech Challenge 2 02-12-2007 22:16
CD-Media tagging standards for FLL/FTC teams? Billfred CD Forum Support 1 15-11-2007 09:27
[FTC]: Hey FTC teams, Vex and a chance to be on MTV? Rich Kressly FIRST Tech Challenge 1 12-09-2007 13:35
