Go to Post FRC did a lot for me in high school. I couldn't pass up the opportunity to help it do the same for others. - Oblarg [more]
Unread 13-02-2008, 08:40
TEAM1949 TEAM1949 is offline
FRC #1949
TEAM1949 is an unknown quantity at this point
How do I change the Gyro & Acc analog chanels?
In Kevins codes how do I do that?
tnx ahead.
Unread 13-02-2008, 08:48
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
Re: How do I change the Gyro & Acc analog chanels?
Look in gyro.h. There's an option to change the analog input that the gyro is connected to.
Unread 13-02-2008, 09:21
FRC #1949
When I do that, I am not able to get any signal.
And what about the Accelerometer?
Unread 13-02-2008, 13:38
Kevin Watson's Avatar
La Caņada High School
FRC #2429
tnx ahead.
Open up adc.h and define the number of channels you want the software to cycle through. The channels must be consecutive and always start at channel 1. Then you can assign the gyro to one of those enabled ADC channels.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-02-2008, 08:17
FRC #1949
Did that (anabled another 2 analog chanenls) and consequently the Gyro won't give me any accurate values. I guess it's because of the change in the sample rates.
What else can I do ? Change some other definitions?
Unread 14-02-2008, 08:19
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Most likely, you'll need to double your sampling rate. Make sure your system can handle this higher interrupt rate before doing it, interrupt timing issues are very difficult to debug once they crop up.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 14-02-2008, 12:01
FRC #2429
This expression, from adc_readme.txt, will allow you to calculate the update rate:
Update Rate = Sample Rate / (Samples Per Update * Number Of Channels)
If you are sampling three ADC channels and left the other settings at the default, you're only getting ~17 updates per second, which is pretty low. You'll want to bump this up to somewhere in the 50-100 updates per second range by raising the sample rate and/or lowering the number of samples per update. For grins, try changing the sample rate to 1600Hz and change the samples per update to 8 and see if it's any better.
-Kevin
Kevin Watson
http://kevin.org
Unread 14-02-2008, 12:42
FRC #1949
Thumbs up Re: How do I change the Gyro & Acc analog chanels?
yup works perfect.
A new question came up - if will increase the opened analog channels by another 2 (for example), I'll have to do this actions again?
How do i change the color of the scroll bar? Compnerd Website Design/Showcase 6 06-03-2007 19:40
Using gyro.c with other analog sensors no go Astronouth7303 Programming 17 03-01-2006 21:04
Need help with Gyro = Analog Devices ADXRS150EB Jack Jones Technical Discussion 9 18-07-2005 07:00
Using gyro with other analog sensors...again demerski Programming 0 19-02-2005 08:23
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
