Go to Post When I'm hiring an intern "Award Winning VRC Notebook" isn't applicable. But "Award winning technical documentation" sure is. - Andrew Schreiber [more]
Unread 13-02-2008, 09:42
Capt Finkiewicz Capt Finkiewicz is offline
FRC #1584
Capt Finkiewicz is an unknown quantity at this point
2 batteries
does any one know if there are any rules about not haveing two of the 12 volt batteries on your robot. one that powers the robot and another for weight in the front of the robot.
i will upload a picture later today so that you can see what i am talking about.
Unread 13-02-2008, 09:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 2 batteries
Yes, there is a rule that specifically says you can only have one 12v battery on your robot.
"<R45> Items specifically PROHIBITED from use on the ROBOT include:
More than one primary battery, or more than one back-up battery"
If you need ballast, find something else! A battery is a dangerous thing.
Unread 13-02-2008, 09:47
FRC #1584
Re: 2 batteries
thanks for the information.
Unread 13-02-2008, 09:48
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: 2 batteries
no its not allowed... just get a ton of steel that you can use as ballast and put it up there (=
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 13-02-2008, 10:05
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Re: 2 batteries
In a game of speed, weight is never a good thing.
Is there a way that you wouldn't have to use ballast, or place the battery up front where the ballast would go.
You don't want weight on fast robots, (but maybe you do) any hints on what your robot is, or what it looks like.
Design. Build. Dew.
Unread 13-02-2008, 10:22
Re: 2 batteries
Ballast is still governed by other rules. Be sure it meets the flowchart for allowables and that it is securely mounted on your robot. Tywraps do not count!
Unread 13-02-2008, 10:38
MrForbes's Avatar
AKA: Jim
Re: 2 batteries
You can buy 5 and 10 lb iron weights at discount department stores, and the have a convenient hole thru the center for mounting.
Unread 13-02-2008, 12:27
mattotters's Avatar
mattotters mattotters is offline
leadership/fab team
FRC #1228 (A-MERK-IN-INDIANS)
mattotters is an unknown quantity at this point
Send a message via AIM to mattotters
Re: 2 batteries
get some lead i litterly have a ton of it in my back yard it works great as a counter weight.
No sleep till the new jersey first robotics regional!
Unread 13-02-2008, 12:36
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: 2 batteries
And Small Parts still sells 27 pound bricks of lead. We have used them in the past as ballast (many, many years ago - ahhhh, for the good old days, when our robots always seemed to come in well under weight instead of well over... )
-dave
Unread 13-02-2008, 13:10
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: 2 batteries
-dave
Hmmm. Years of handling lead; that might explain some things...
On a philosophical note, does a battery count as a battery if it's not part of the electrical system? Yes, yes, I know the rules about one and only one 12v primary battery, but if it's not plugged into anything is it really a battery? Is it not just a battery shaped weight? Not that I'm advocating for using extra batteries as weights, but still an interesting point of discussion.
Unread 13-02-2008, 14:09
EricH EricH is online now
Re: 2 batteries
Is a battery a battery if it's not part of an electrical system? If not, then someone needs to go after Duracell and Energizer for false advertising.[/sarcasm]
Seriously, I would argue that a battery is a battery at any time. If it is only a battery when current is flowing, then anytime the main breaker is hit, the battery becomes a battery-shaped weight. If it is only a battery when hooked into the electrical system, then you're charging a battery-shaped weight. (Don't get any ideas.)
More importantly, a battery has the potential to suddenly become a spark generator at any time. As soon as it hits metal on both contacts, it becomes a safety hazard, but it may or may not be plugged into an electrical system. Is it not a battery then?
Unread 13-02-2008, 14:30
Re: 2 batteries
Gentlemen,
Although lead seems to be an ideal ballast material, remember that in some areas lead is considered a hazardous material. It may not be cut or machined at events and should be painted or coated to prevent students (and mentors) from ingesting contaminants while eating with their hands.
Unread 13-02-2008, 14:37
HUNT397's Avatar
HUNT397 HUNT397 is offline
AKA: Chris Hunt
FRC #0397 (Knight Riders)
HUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to beholdHUNT397 is a splendid one to behold
Re: 2 batteries
Last year we filled two acculator tanks with lead shot worked great because we were not using air and you can fit about 5lbs into one, (i think) and it is sealed with two plugs.
Unread 13-02-2008, 14:51
AKA: Dan
Re: 2 batteries
Ahh, so a battery by any other name is still a battery. I think this is the most important argument against using a battery as a weight, especially when there is plenty of other heavy stuff around that can be used. How about a box of old motors?
Unread 13-02-2008, 14:53
MrForbes's Avatar
AKA: Jim
Re: 2 batteries
...the old motors would have to be currently available COTS
Batteries Mike Martus General Forum 26 19-02-2007 12:47
MK Batteries Mike Martus Electrical 0 11-01-2007 10:09
Batteries Der Sichelmann Electrical 18 22-02-2005 22:17
Batteries MechaJagEric Electrical 9 21-02-2003 12:48
Batteries MechaJagEric General Forum 2 27-01-2003 21:18
