Go to Post Remember to drive it like you stole it but be sure that it is in OVERDRIVE. - Steve W [more]
  #31   Spotlight this post!
Unread 12-02-2008, 16:40
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: Shooters vs Arms
I personally feel that a combination of both a shooter and arm are vital to this year's game. Shooters are fast at some things, and absolutely horrible at others etc. placing on top of overpass. Arms are the same way. They both have their pros and cons, and to work to the best of their abilities, must work together to score the maximum number of points. We have an arm this year, but have come up with a way to score more points than the average arm....wait and see.......
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
  #32   Spotlight this post!
Unread 12-02-2008, 19:08
Kellen Hill's Avatar
Kellen Hill Kellen Hill is offline
Strategist
AKA: The user formerly known as 'hill'
FRC #1746 (OTTO)
Kellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond reputeKellen Hill has a reputation beyond repute
Being able to set the ball up on the overpass gives you 12 points while doing another hurdle and crossing the line gets you 10. Where is the major advantage in 2 more points?
1625 Winnovation Member: 2005-07
1625 College Mentor: 2007-11
525 Swartdogs Mentor: 2011-12
1746 OTTO Lead Mentor: 2013-Present
  #33   Spotlight this post!
Unread 12-02-2008, 20:23
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Well, four more points, because you could also drive under after you place the ball. (or push the ball under, drive under, and put it up for 6 more points!)
But I think the real advantage to the placing the ball at the end is that you can do it on either overpass (correct me if I'm wrong...). So if you are stuck on the wrong side of the field and need a quick 12 points to win the match, placing the ball up is the way to go.
  #34   Spotlight this post!
Unread 13-02-2008, 00:11
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
Well,
1. Shooters can have mechanisms to knock the ball down. I know my team does and,
2. A hurdle at the end of the game rather than setting it back on the overpass is just as good, you just miss out on a couple points.
I think effective shooters will dominate this years game.
I disagree,
My team has built a shooter but I think that well-built lifters will provide major competition.
A well-built, fast, and coordinated lifter will be just as powerful as a shooter in my opinion. Some teams have already proved this with their videos they have released.
Sam N.
Mitty Robotics Alumni
TKO 1351
  #35   Spotlight this post!
Unread 13-02-2008, 00:48
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I wouldnt be so quick to state that if i were you (=
in the end, the only major advantage that a shooter has over a lifter is that they dont need to stop in order to score. However, like lifters, they also have a range of scoring positions. For example, for a lifter to score, it will typically need to be right in front of the overpass before releasing the ball so that it can go over. With a shooter, if it is too close the ball will hit the underside of the overpass, and if it is too far away it might not go over altogether.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
  #36   Spotlight this post!
Unread 13-02-2008, 06:04
Tim Arnold's Avatar
Tim Arnold Tim Arnold is offline
1902 UCF Mentor; 1523 MARS Alumni
FRC #1902 (Exploding Bacon)
Tim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond reputeTim Arnold has a reputation beyond repute
Send a message via AIM to Tim Arnold Send a message via MSN to Tim Arnold
Originally Posted by ggoldman View Post
Shooters
Cons:
Cannot Place on Overpass at end
Can be "Blocked" easily
Cannot (on their own) knock down balls off overpass.
Don't be so sure. As others have said, there is no reason that a properly built thrower can't also place on the overpass and knock down balls... and what if the release point is at 5 ft?
Another bot would have an awfully hard time getting in the way to start with, and then the 10lbs + momentum of the ball would be impacting the blocking robot 6ft in the air or so. I smell tipsy robots.
  #37   Spotlight this post!
Unread 13-02-2008, 10:01
jacob07's Avatar
jacob07 jacob07 is offline
AKA: Jacob
FRC #0397 (Knight Riders)
jacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to behold
Send a message via AIM to jacob07
Originally Posted by s_forbes View Post
Who says a shooter robot can't take a ball down and put it back?
If teams were thinking ahead like they should be they should be able to knock the ball down, it wouldn't be that hard to make something to do that....would it?
Also if you were a shooter, wouldn't you have tested the tar outta of it? shouldn't you be able to get yourself in range of the overpass to be able to shoot it and land on the overpass, all it takes is testing and figuring out how far back you would have to be.
Just my two pennies
Jake
  #38   Spotlight this post!
Unread 13-02-2008, 11:13
run the trap!!!
Team Role: Human Player
Originally Posted by Swampdude View Post
It's always true how you execute your design is the deciding factor as to how successful it will be. However 118 showed how easy it is to make a great launcher. We contemplated copying that when we saw it. It would have been easy to do (the launcher anyway). I'll bet a number of teams did. Why not?
However, all things being equal, this simply is the most efficient solution, mainly because of the clothesline factor. When executed properly you can't score faster with a mechanism that goes above the overpass for a period of time during the score. So how you get the ball off the ground becomes important, but no reason a shooter can't use the same mechanism an arm can.
Yes there will be plenty of arms scoring faster than shooters, but that will be because of execution or techniques. But if done right I can't see how even the best arm (anything that goes above the overpass) could score faster than the best shooter.
Exactly.
One thing I've noticed is that many of the successful "arms" are VERY adept at picking up the balls quickly (rollers: 121, 179, 1902...)
Yet they are slightly slower when it comes to hurdling.
The catapults on the other hand, excel at hurdling, but struggle to pick up the ball.
I believe that in the end the two designs will hurdle equally fast. Catapults will hurdle faster, and arms will pick-up faster. (provided of course that both designs are properly executed)
This is all the result of engineering trade offs...
-Philip J. Fry
  #39   Spotlight this post!
Unread 13-02-2008, 11:21
jacob07's Avatar
AKA: Jacob
Originally Posted by Hachiban VIII View Post
Exactly.
couldn't you theoretically combine both methods, have a arm lift the ball to the launcher?
  #40   Spotlight this post!
Unread 13-02-2008, 11:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We have an "arm" that picks up the ball just fine and loads it on the launcher.
It turned out that it is much easier than we thought it would be.
  #41   Spotlight this post!
Unread 13-02-2008, 11:31
Strategist
FRC #1746 (OTTO)
Originally Posted by Sam N. View Post
I disagree,
Sam N.
I agree with you, and think that they will provide lots of competition. It is just my opinion that I think "effective" shooters will dominate the game.
  #42   Spotlight this post!
jacob07's Avatar
AKA: Jacob
IMO those kinds of robots are going to be the winners in the end
  #43   Spotlight this post!
Unread 13-02-2008, 11:52
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Our shooter has a fork on the front ( similar to 1726) and we can get the ball on the run. I have actually found it easier than it was to pick up ringer with our arm last year. Many less capable arms will requier more aiming to pick the ball up just right. I think where the shooters will gain the advantage is precision. Shooters can be a little (for lack of a better word) sloppier can still score. I would even dare to say easier to build and upkeep.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
  #44   Spotlight this post!
Unread 14-02-2008, 09:32
Spartan151's Avatar
Spartan151 Spartan151 is offline
TCU Bound (Class of 2013)
AKA: Sean
FRC #2920
Spartan151 will become famous soon enough
I'll tell you from firsthand experience that even though arms are a good idea, shooters are going to make the points. Our problem that we've had since week 3 (When we started on the arm) is that....well, the arm motors can't lift the combined weight of the arm, the claw, and the ball. So, we tried a lighter arm. Still couldn't lift the combined weight. Given the fact that our team doesn't have much to work with, we changed strategy.
Shooters have their advantages, and so do arms. They both have their cons. Just depends on what you want to do, really.
MORE DUCT TAPE!
  #45   Spotlight this post!
Unread 14-02-2008, 09:53
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Shooters all the way. Yes arms can get the balls on top if need be, but frankly people, the balls can easily be knocked off the overpass almost as easily as they were put up there. It's similar to 2003, it was too easy to remove the big points.
Horizontal Shooters Sachiel7 Technical Discussion 10 24-02-2006 08:12
2 Shooters??? Jon Jack Robot Showcase 14 26-01-2006 20:00
Shooters or Nonshooters Kevin_547 Rules/Strategy 6 21-01-2006 22:28
Female Shooters JulieB Championship Event 29 28-04-2004 16:47
Pure Shooters Andrew Rudolph General Forum 5 04-03-2002 20:53
