Go to Post The best parts of FIRST just cannot be described. They have to be experienced. - sanddrag [more]
Unread 13-02-2008, 10:36
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
Re: Attempting to Drive Straight with Gear Tooth Sensors and Gyroscope
Linx34,
A few qestions... What rate are you receiving gear tooth pulses (how many pulses per foot of travel)? Are you monitoring your PWM output, and if so, what kind of swing are you getting while you are "driving straight"? The reason I ask is that you could either be overcorrecting and the robot is not able to respond quick enough so you are seeing it oscillate arround the "correct" PWM value, or it could be that you are not seeing a difference between the left & right gear tooth sensors quick enough, although in this case I would expect it to take too long to actually start driving stright, but once it gets there, it should be fairly good. Just checking, but you are not zeroing your gear tooth counter while running the code correct? (and the joystick difference doesn't occasionally go above 5 while going straight) Also make sure are not running your PWM outputs near the limits (<30 or >225) as you may near the limits of the Victor or motor.
Mike
Help with the Kit Gear Tooth sensors Keo-san Programming 9 20-02-2007 08:07
Gryo, Camera, Accelorometer, Ultrasonic, and Gear Tooth Sensors in one program EHaskins Programming 8 22-05-2006 12:08
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
