Go to Post I would love access to the crystal ball granting you the insight into these changes. - sdcantrell56 [more]
Unread 13-02-2008, 04:07
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Question Electronics Board Wiring Concern
When i saw that we needed 6 Victors i became concern of where to ground them all. the First Wiring Diagram indicated to route them into the distribution block at the top. Since at the time we didnt think we would have enough space for 6 or more grounds we instead routed a single black 6AWG GND wire to the ATC fuse Block and then connected to the Victor Grounds from there. (blue wires)
How would a judge feel about this? is it fine, or is rerouting needed?
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 13-02-2008, 04:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Electronics Board Wiring Concern
*Inspector
Your wiring method is perfectly acceptable, confirmed by a post in the official FIRST Q/A forum.
Unread 13-02-2008, 06:35
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
That is fine, but your jumper from the Maxi block to the ATC fuse block is illegal.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 13-02-2008, 09:35
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
You would be better off running the grounds from your drive motor victors to the din-rail ground rather than to the fuse block. Also you can take out 2 of the red din-rail blocks since you only really need 2.
-Mike
Unread 13-02-2008, 10:13
Osc,
As posted above the red (positive) wire may not pass through the maxi block to the ATA block. It should be easy to replace.
Although the GDC has ruled that it is OK to return your motor wiring to the ATA block, I still recommend that high current returns be terminated on the Rockwell. block. Remember that the block can accept 2 #10 or #12 wires per terminal.
Don't forget that unused sections of the block may be removed for a weight/space savings.
Unread 13-02-2008, 10:59
EtherealNinja EtherealNinja is offline
EtherealNinja is an unknown quantity at this point
Osc,
What problems might a team face if they do connect the ground returns to the ATC panel?
In other words, is it just considered "good practice" or are there some real safety concerns with doing it?
Unread 13-02-2008, 11:08
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's more of a performance concern, the less load there is in the wiring that provides power to the RC, the better. Sharing the RC power wires with the motor power wiring leads to excessive voltage drop at the RC and could cause it to reset, I believe.
So, run separate big fat wires from the Power Distribution Block to each of the load centers (MaxiBlock, ATC panel, Victor returns, etc)
Unread 13-02-2008, 12:15
As Jim pointed out, current for a motor/Speed controller flows through both wires. Current flowing through a wire (red or black) will develop a voltage across the wire that detracts from the voltage available to the load. If you split the high current wiring as near to the battery as possible(at the Rockwell block), then less voltage is dropped to the circuits downstream. The critical component is the RC which drops out below 8 volts. When that occurs, all PWM outputs are disabled and the RC switches over to the backup battery to stay alive and keep up the modem and communications with the OI. Luckily there is some capacitance in the RC that allows it to weather short duration brownout conditions. If you have 6 drive motors and they all go into stall condition at the same time, it is easy to draw enough current to drop down to 6 or less available volts.
ABS Electronics Board Ian Curtis Electrical 3 07-01-2008 23:25
pic: Top of electronics board keenanmolner Extra Discussion 4 19-02-2007 00:57
pic: Side of electronics board keenanmolner Extra Discussion 1 18-02-2007 20:15
pic: practice electronics board sonofdad123 Extra Discussion 5 23-01-2007 21:01
pic: 1023 Electronics Board KTorak Robot Showcase 1 13-02-2006 21:57
