Re: GTS Encoder Compilation Error
-Kevin |
Yes. And then I edited the .h file and saw that it still had INT3P instead of INT3IP and I changed it manually and saved the file. I restarted MPLAB and recompiled and get that error every time.
You should not have needed to edit the file, you probably recreated the problem when you edited it.
I only edited it after testing it untouched and having it fail. Then I read the 5 or 6 posts about the issue and they all pointed to a very specific typo and to the best of my ability I found the problem and changed INT3P to INT3IP.
Yes, this is a known bug in the provided mcc .h file.
I went through the same exercise and by changing the INT3P to INT3IP in mcc18/h/p18f8722.h it fixed the problem for me. Is there a local copy of the the include file in your project directory? Try renaming the mcc18/h/p18f8722.h file to h_ and try recompiling. If it doesn't complain about not being able to find the file, then it is using a copy from somewhere else. Also, make sure the error is the same. I had some code that referenced the field as INT3P and fixing the include file kick the error of not being able to find INT3P -- a quick look might mistake this for INT3IP. |
Not sure what you mean in your second point. I opend the 8722.h file and searched for all INT3P and changed it to INT3IP but the error persists. |
| Encoder, GTS, Gyro, Camera != Work | purduephotog | Programming | 1 | 18-02-2007 17:20 |
| Encoder Error | Anime-niac_2.9 | Programming | 1 | 27-01-2007 16:23 |
| GTS Code Error (the red light of doom!) | Denz | Programming | 9 | 07-04-2006 17:39 |
| FIRST DVD Compilation | Mark McLeod | General Forum | 10 | 14-12-2005 02:02 |
