Go to Post "The purpose of computation is insight, not numbers." - Tom Ore [more]
Unread 13-02-2008, 15:05
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Limit Switch Problem
Just to make note I don't really know if this goes in the Electrical or Programming...so move it please if its in the wrong one.
Ok, right now I'm having some problems to get the limit switch to work. We have it in "digital_io_18". the code is a simple.
if(digital_io_18 == 1)
 printf("Switch = %d",digital_io_18);
digital_io_19 = INPUT;
The problem is that its not changing states, but the controller LED "RC Hardware" is turning yellow(aka +5V output low) when its pressed
PS we have the switch on "normally closed"
PSS we are using kevin's 3.0 code
Unread 13-02-2008, 15:13
jln646v jln646v is offline
AKA: Vincent Juliano
FRC #0514 (RPM)
jln646v is an unknown quantity at this point
Send a message via AIM to jln646v
Re: Limit Switch Problem
Why are you using digital_oi_18? Why dont you just use rc_dig_in18? I am not sure if this is the same thing but it might be your problem.
if (rc_dig_in18==1)
printf("");
Also, when you say your rc hardware light is yellow, your not shorting out the digital input are you? Make sure you are connecting the ground and signal pins, not the ground and +5.
Unread 13-02-2008, 15:25
Boydean's Avatar
The Blue Alliance
Danke, that did it. We did in fact have the +5v plugged into it. That was a bad thing.
Unread 13-02-2008, 16:32
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
All the digital pins are INPUT/OUTPUT pins. digital_io_18 is used to set whether the pin is used for input or for output. If it is used for input, then rc_dig_in18 is used to read the value.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Using a limit switch thunderbolt Programming 1 02-04-2007 19:36
limit switch wedellm Electrical 4 16-02-2007 13:01
Limit switch in easy c? chadbarbe Programming 6 02-02-2006 09:51
