Go to Post first post and the FRC "well what is a stick" comes in. Toothpick, does it need to be round, does a carbon fiber chain of Buckie balls count as a stick. CD posters are sooooo predictable. - Foster [more]
Unread 13-02-2008, 16:21
mayazk mayazk is offline
FRC #2596 (FBI Robotics)
mayazk will become famous soon enough
Send a message via MSN to mayazk Send a message via Yahoo to mayazk
Easy C pro help !!
HI to all
and all those who help Thanks alot(excluding viewers only) lol
my question is
Can i use the OITorelay with the limit switch?how?
Can i program the buttons on the joystick for the limit switch?
Thanks alot
Ayaz Khan
Unread 13-02-2008, 22:42
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Easy C pro help !!
I think one of us may be confused by your question. Where does the limit switch figure into this? OIToRelay simply takes an input from one of the OI ports and sends it directly to a relay (Spike). Do you want to wire a limit switch to an OI port? Maybe I'm not getting what you think a limit switch is.
Unread 14-02-2008, 15:48
Well no i just want to hook up a lmit switch so the gliders that we are making stop at a certain point. This way the motors will not burn out so let me restate my question
How do i hook up the limit switch to the robot controller ?
because the limit switch will be on the gliders and the wires will go down into the robot controller
therefore i need to know how to connect the two
THANKS
Ayaz Khan
Unread 14-02-2008, 15:51
one more question
what does "retrieve" refers to
Ayaz Khan
Easy C pro Hybred mode? Mentor08 Programming 3 04-02-2008 17:21
2008 Easy C Pro G1279 Programming 2 17-01-2008 13:01
Easy C Pro RRA4LIFE2 Programming 6 16-01-2008 17:25
From MPLAB To EASY C PRO 354.FIRST Programming 4 30-01-2007 17:13
