Go to Post At the end of the day, every team in FRC has accomplished something amazing in the sculpting of the next generation of leaders. - Elliot191 [more]
Unread 13-02-2008, 15:59
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Potentiometer problems
We have a strange issue with our pots.
Situation:
The potentiometers are wired properly, Power to pin 1, Signal to pin 2, Ground to pin 3, and connected to a PWM connector. We have tried this with 3 separate potentiometers, and they work properly when examined with a Digital Multimeter. However, when connected to the Robot Controller, a strange thing happens. The potentiometers start out giving the value off them as 70, however their output rapidly drops down to around 40, and then starts dropping slowly. The drop appears to be a logarithmic function. We've checked that it's wired to the proper port, plugged in the right way around, wired to the right pins.
Is there anything you can think of that would cause this kind of behavior?
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 13-02-2008, 16:13
Kev Kev is offline
The Greatest
FRC #0614 (Nighthawks)
Kev is an unknown quantity at this point
Send a message via AIM to Kev
Re: Potentiometer problems
pots go into Analog inputs, don't they?
Unread 13-02-2008, 16:47
Racer26 Racer26 is offline
Are you reading the pot using Get_Analog_Value(rc_ana_inxx);? if you're not, and not using kevin's equivalent, that might cause it. Also, I would check for any debris that might be shorting something on the RC.
Unread 13-02-2008, 16:48
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Situation:
Check your backup battery.
From the RC Reference Guide:
The Battery Backup circuit also supplies power to the center pins of the PWM OUTPUTS,which is required to operate servos
Unread 13-02-2008, 16:59
rachal's Avatar
multipurpose tool
AKA: Rachel
Okay, we hooked it up to a scope and it looks like the limit switches were grounding all the analogs when they were hit. I'll post again if the problem is elsewhere.
Unread 13-02-2008, 17:00
billbo911's Avatar
Okay, we hooked it up to a scope and it looks like the limit switches were grounding all the other analogs when they were hit. I'll post again if the problem is elsewhere.
OUCH!!!
Limit switches go to Digital inputs.
Unread 13-02-2008, 17:03
rachal's Avatar
multipurpose tool
AKA: Rachel
Oops, never mind
No, the limit switches were plugged into digital and the pot was analog, but the limit switches were shorting the entire RC
Unread 13-02-2008, 17:19
billbo911's Avatar
Oops, never mind
Are your switches shorting +5vdc to GND?? Not good!
Switches need to be wired between SIG and GND.
Unread 14-02-2008, 08:27
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Are the pots linear taper? Check with an ohmmeter with no power to it.
Brian K
Team 1225 Robotics Mentor
Potentiometer PID DustinB_3 Programming 28 15-02-2008 23:18
Potentiometer Problems Nicole_Ypes Electrical 7 08-02-2007 18:59
Potentiometer fezkazi Electrical 3 24-01-2007 13:29
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
