Go to Post You know you've made it big when people assume every imperfection is genius! - araniaraniratul [more]
Unread 12-02-2008, 22:07
379robocatCaine's Avatar
379robocatCaine 379robocatCaine is offline
AKA: Mr.Fix it
FRC #0379 (Robocats)
Team Role: Driver
379robocatCaine is an unknown quantity at this point
Send a message via AIM to 379robocatCaine Send a message via Yahoo to 379robocatCaine
pic: TEAM 379 ELECTRONICS TEASER, THE ROBOCATS
Unread 12-02-2008, 22:08
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Re: pic: TEAM 379 ELECTRONICS TEASER, THE ROBOCATS
nice electronics box. how much does that thigh weigh, and what are you using for your "easy-disconnect"?
Unread 12-02-2008, 22:16
DragonRagnarok's Avatar
DragonRagnarok DragonRagnarok is offline
AKA: James Gregoire
FRC #0172 (Northern Force)
DragonRagnarok is an unknown quantity at this point
Send a message via AIM to DragonRagnarok Send a message via Yahoo to DragonRagnarok
Firstly, "caps lock is not cruise control for cool"
Second, I'm skeptical about how effective that design will be once you actually have all your PWMs, relays, and sensors wired. In order to maintain the slide-out ability, it seems to me you'll need a whole mess of long wires connecting everything, resulting in a very messy setup which will be quite a bother to debug. And won't you still have to unscrew every motor wire and unplug every sensor and relay to remove that box?
Cheers,
James
Unread 12-02-2008, 22:50
Kyle379's Avatar
Kyle379 Kyle379 is offline
Rockin the red tie-dye!
AKA: Kyle Pearson
FRC #0379 (RoboCats)
Kyle379 has a spectacular aura aboutKyle379 has a spectacular aura aboutKyle379 has a spectacular aura about
Send a message via AIM to Kyle379
The box and contents weighs just under 10 pounds. The wires/pwm's coming from the controller run back and fold open with the "lid" and meet the rest of the wires which run through channels (no mess). The idea of it being able to disconnect is a necessity due to the design of the robot. It's more for ease of a quick fix than anything else. On the robot the wires coming from the motors/sensors all meet plugs which allow us to disconnect there. The team wasn't able to meet today because of the bad weather so this box was worked on by a student at home. He was so proud of his work he decided to explain in caps, I would . . . Go Caine!
Unread 13-02-2008, 18:12
neonx neonx is offline
neonx is an unknown quantity at this point
those lights will have to be removed, other then the official lights and such, those are illegal. even worse being green because cmucam is default green :/
Unread 13-02-2008, 18:20
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
Nice creative design, I like the way you mounted items upside down. Very clever.
Unread 13-02-2008, 18:21
Where do you get this? They are legal this year. (If you are using a CMUCam, then you can request that any team in your match using these turn them off.)
Unread 14-02-2008, 01:10
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Ooo! I like the "Borg lighting" trend I've been seeing for electronics. Nice work!
pic: TEAM 379 DRIVE TEASER, THE ROBOCATS 379robocatCaine Extra Discussion 6 12-02-2008 23:10
pic: Electronics from the Rockie Team #2422 Bucket o' Bolts ccontreras1507 Extra Discussion 4 10-02-2008 20:44
pic: 379 2007 Robot Robo_Cat_379 Robot Showcase 2 23-02-2007 18:10
looking for team#379 omccadney General Forum 0 04-02-2003 19:08
